Saftey map?
Kaan W
My car seems very slow lately and after noticing its only boosting to 1bar and not the 1.8 as mapped could be the answer. I have tried using the Syvecs software but it makes no sense to me but all I can think of is it must be running as a base map for some reason. Has anyone experienced this issue do I need to unplug the battery and re connect?
Edited by Kaan W (see edit history)
Just a stab in the dark but have you got the cal switch to the right setting (if you have multiple maps)?
Yeah but the first 3 are now 1Bar which are meant to be 1.8 and 4-6 are about .7 of a Bar which and meant to be 1Bar.
Check the plumbing of the wastegate, boost pipes etc
The syvecs won't go back to a base map.
Are you sure you didn't disturb something when you fixed the oil leak problem?
Ok guys I will check everything over, pretty sure something's up tho as its done it ever since it cut the engine out.
Actually what is the plastic box with a wire where the vacuum pipes connect to? It's like a T piece but only 2 pipes connected which I took one off when fixing the oil leak, could I of put it back on the wrong one would this cause the problem?
It will be a boost / vac leak and the car simply cant generate more the 1 bar boost, you seriously need to sort all these issues with your car mate , I have never know a single build to have so many issues in such a sort time, good luck with it mate stick at it and do it right hodges thread is a good read for info onhow a build should be done
Just a simple mistake really when fixing my oil leak it came off and I took a rough guess at which port to put it on.
And you wonder we you have so many problems , by taking a wild stab at it lol, for god sake man leave the car alone , and if you come to sell this car you might be better off not selling it on here as its got nothing but bad press, which you 99% have caused your self
Easily done. I did the same with putting brake fluid in. I know it was one of the bottles but the paint seems to have peeled off near the windscreen since.
Bit harsh? And I would imagine a fair few would buy my car when everything's finally done and it hasn't got a bad press at all.I would never sell this with problems which is why I have spent thousands getting the car right, besides ive not even had it a year there's bound to be little things here and there which everyone experiences. I just ask more than others I suppose. By the time I come to sell, the car will be bullet proof as im going for a full rebuild over next winter built block the lot.
- - - Updated - - -
:D Seriously?
