Brazil Posted March 2, 2013 Share Posted March 2, 2013 I am needing new tyres for my Volk wheels 19'' 10.5'' in the rear and 9.5'' front. I have rolled arches all round and currently have Toyo R888 295-30-19 in the rear and Bridge Stone Potenza 245-35-19 in the front. Since I have changed coilover and lowered further my car my front wheels look like it would benifit from spacers to push them out to the arches, so I thought I may be able to get around this by changing the fronts to Toyo R888 all round and go wider in the front to 255-35-19. As you know the R888's have a square shape so it could just do the trick. Unfortunantly from searching I found that there isn't R888 in the 255/19'' size I need. I would really like to have matching tyres all round so what else would you recomend? Another issue which I am thinking about is the side wall '30' in the rear, is it to thin? Would I not benifit from a bigger side wall which will help with grip? Please help me out and recommend me the perfect tyre set up for my 19'' wheels that would peform well with 700bhp. I used Camskill, but would like to know who else do you recommend? Link to comment Share on other sites More sharing options...
Brazil Posted March 3, 2013 Author Share Posted March 3, 2013 Bump.... Link to comment Share on other sites More sharing options...
David P Posted March 3, 2013 Share Posted March 3, 2013 If it's traction your wanting, then the 19" need to go. Link to comment Share on other sites More sharing options...
Luxluc Posted March 3, 2013 Share Posted March 3, 2013 Toyo will be fine for 700bhp. They have a stiffer side wall than my actual Michelin Pilot Sport Cup. This helps traction. My Michelins were fine with my old setup with 650 rhhp. Luc Link to comment Share on other sites More sharing options...
Dnk Posted March 3, 2013 Share Posted March 3, 2013 Wouldn't you want more sidewall and so less stiff for more traction hence drag cars run big profile tyres that flex and grip Link to comment Share on other sites More sharing options...
Luxluc Posted March 3, 2013 Share Posted March 3, 2013 18" would of course improve traction due to a 35 series. I was told that on 19", the 888 is a good semi-slick option. Link to comment Share on other sites More sharing options...
Dnk Posted March 3, 2013 Share Posted March 3, 2013 (edited) Ignoring speedo error and gearing, for traction a 295 35 19 will be better than the 295 30 19 as you'll have 15 mm more sidewall. If you went to 40 then you'd have nearly 30 mm more sidewall but compared to stock your now 13% bigger in diameter or 83 mm Edited March 3, 2013 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
welshbuddy Posted March 3, 2013 Share Posted March 3, 2013 get on camskill bargain Link to comment Share on other sites More sharing options...
Brazil Posted March 4, 2013 Author Share Posted March 4, 2013 (edited) Dnk said: Ignoring speedo error and gearing, for traction a 295 35 19 will be better than the 295 30 19 as you'll have 15 mm more sidewall. If you went to 40 then you'd have nearly 30 mm more sidewall but compared to stock your now 13% bigger in diameter or 83 mm The problem is also that I like to have Toyo R888 all round but Toyo do not make the size I like for the front, do many of you guys mix tyre makes? Edited March 4, 2013 by Brazil (see edit history) Link to comment Share on other sites More sharing options...
Luxluc Posted March 4, 2013 Share Posted March 4, 2013 I don't mix tyre makes. I want a proper tire on the front too, as I don't only drive straight line. Link to comment Share on other sites More sharing options...
sdistc Posted March 4, 2013 Share Posted March 4, 2013 I was still running a 265x30x19 Yokohama Advan on the fronts (19x9.5 Rays GTS) after the rears um.. "wore out" and I switched to the R888s. You might find the 265 fits well enough for you in the R888 as well. Link to comment Share on other sites More sharing options...
Luxluc Posted March 4, 2013 Share Posted March 4, 2013 265 for the front on a 9.5 will be fine. Link to comment Share on other sites More sharing options...
Brazil Posted March 4, 2013 Author Share Posted March 4, 2013 sdistc said: I was still running a 265x30x19 Yokohama Advan on the fronts (19x9.5 Rays GTS) after the rears um.. "wore out" and I switched to the R888s. You might find the 265 fits well enough for you in the R888 as well. Were you able to buy 265x30x19 Toyo R888's? What arch work did you have? How did your Advan compare to R888's? Link to comment Share on other sites More sharing options...
Luxluc Posted March 4, 2013 Share Posted March 4, 2013 Check for the R888 sizes and prices here. http://www.renn-reifen.de/images/stories/preisliste_kunde/kunde_toyo_r888_1301_reader.pdf Luc - - - Updated - - - What offset do you have on the VOLK? Link to comment Share on other sites More sharing options...
sdistc Posted March 4, 2013 Share Posted March 4, 2013 Brazil said: Were you able to buy 265x30x19 Toyo R888's? What arch work did you have? How did your Advan compare to R888's? Nah, sold the car before I needed to replace the Yokos. No arch work needed at the front - offset was pretty good, but heavily rolled rear arches. R888s gave me complete traction all the time (30psi on 71 mm single turbo). Yokos would spin up to 4th gear. Didn't really drive the car hard around corners, so don't know much about the lateral grip though. Link to comment Share on other sites More sharing options...
Brazil Posted March 4, 2013 Author Share Posted March 4, 2013 Luxluc said: Check for the R888 sizes and prices here. http://www.renn-reifen.de/images/stories/preisliste_kunde/kunde_toyo_r888_1301_reader.pdf Luc - - - Updated - - - What offset do you have on the VOLK? I am not 100% sure what offset they are but from looking at this site http://www.upgrademotoring.com/wheels/gt-av.htm and knowing that I have huge brake discks 'endless 14.1'' in the front and +/- 12'' is it possible to guess it? FYI: Front wheels should be 9.5'' wide and rears 10.5''. Link to comment Share on other sites More sharing options...
