tina n paul Posted February 28, 2013 Share Posted February 28, 2013 heres pic top arm ball joint , im pretty certain it shouldnt be like this but would it cause knocking occasonally when going over bumps , im just removing it to check for play , Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 28, 2013 Share Posted February 28, 2013 You don't have to remove it to check for play Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 28, 2013 Share Posted February 28, 2013 [ATTACH=CONFIG]165079[/ATTACH] heres pic top arm ball joint , im pretty certain it shouldnt be like this but would it cause knocking occasonally when going over bumps , im just removing it to check for play , What do think is wrong as i can't see anything obvious Quote Link to comment Share on other sites More sharing options...
tina n paul Posted February 28, 2013 Author Share Posted February 28, 2013 What do think is wrong as i can't see anything obvious basically im getting knocking clunking noises when going over lumps or bumps in the road top mounts look fine no play , ive checked everything else for knocking try as hard as i might it wont do it unless its out on the road , somebody else had same problem he was told it was the shocks but there not leaking and respond well to up and down movement whilst im bumping it up n down , Quote Link to comment Share on other sites More sharing options...
stevie_b Posted February 28, 2013 Share Posted February 28, 2013 Might not be this, but make sure your subframe bolts are tight. They can cause knocks. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 28, 2013 Share Posted February 28, 2013 Damper, spring, arb drop links, ball joints, bushes is where i'd be looking and check the subframe bolts while your at it with a torque wrench preferably Quote Link to comment Share on other sites More sharing options...
trebor69 Posted February 28, 2013 Share Posted February 28, 2013 I have same knocking, all bushes have been checked, new drop links and ARB bushes, top mounts are good too, no play anywhere, shocks do not leak and respond well but MUST be the culprit, have heard that the wear does not show as its on the inside of the shock . Quote Link to comment Share on other sites More sharing options...
trebor69 Posted February 28, 2013 Share Posted February 28, 2013 Subframe bolts are torqued to spec too . Quote Link to comment Share on other sites More sharing options...
tina n paul Posted February 28, 2013 Author Share Posted February 28, 2013 Same here guys but here is a thought , whilst i was under there i had a good look around and could see that lower engine mounts were close to the subframe , upon closer inspection could see where the metal edge of the mount was striking the plate ,A clean metal area , but when i try to move the engine it don't budge or clunk , could it be up n down movement causing the knock ? As tbh it does sound lower in the footwell Quote Link to comment Share on other sites More sharing options...
Shane Posted February 28, 2013 Share Posted February 28, 2013 Could be many different things. My son spent an age trying to get to the bottom of knocking on his prized Civic recently. Ball joints, shock mounts, exhaust and everything you could think of. Everything except the hairpin springs on his brake pads that had been left off when the pads had last been changed:d Good old Dad found it in a few minutes, but through luck more than judgment. Quote Link to comment Share on other sites More sharing options...
tina n paul Posted February 28, 2013 Author Share Posted February 28, 2013 Well were going to the meet tomorrow night will take some of you round the block and you can here it , Quote Link to comment Share on other sites More sharing options...
mattdavies Posted February 28, 2013 Share Posted February 28, 2013 What torque are the sub frame bolts ment to be ? Quote Link to comment Share on other sites More sharing options...
trebor69 Posted February 28, 2013 Share Posted February 28, 2013 What torque are the sub frame bolts ment to be ? If you go to the "Home" page and look in Repair Manuals under Maintenance .....you will find these . Quote Link to comment Share on other sites More sharing options...
