de-cat again.
black cat
sorry if this has been covered a million times, How much is a mid-de cat pipe (fitted) and what will it alter? bhp, sound, or nothing.?? plus will it have any adverse affects on boost pressure. Basically is it worth just having de-cat on its own or is it gona cost wadds to make it good.???? :thanks:
TT steve.
I see you have a j-spec, normally it is recommended that you de-cat both cats and use a restrictor ring to put some backpressure back in the system.
Not sure about just removing the second cat, but anything that reduces the back pressure can raise the boost on a j-spec, more boost = more power. Just ensure you stay at 1.2bar or below for a decent turbo lifespan...
You mean restrictor? That you wont need because you have to have the conroller to get the boost UP, its not like the JDM models that need controlling/taming if you will.
Best be honest with insurance, who knows what sort of accident you could be involved in, for example if you're trapped in your car and cant remove anything or even disabled after and not able to to fiddle with your car! Whose to know what could happen.
boost controller aaaaaaaaaaaaaaa......... will 200 quid do it??
tt steve
Steve, you shouldn't need a boost controller on your J-spec, Bobbeh was talking about the UK Supra which is a little different.
Removing both cats on your J-spec should increase boost pressure significantly, as the cats are very restrictive. In most cases it is neccessary to fit a restrictor ring (simple plate with smaller hole in it) to keep the boost to below 1.2bar.
Before increasing boost you should check the condition of your intercooler, if it is in poor condition it may not be up to the job. You will also need to fit a boost gauge, so you can monitor things. You will probably also need cooler grade of spark plugs fitting, to prevent misfire at high boost.
To be on the safe side, it would also be a good idea to fit a higher flowing fuel pump (Walbro 255l/h or UK spec) and a new fuel filter (Toyota).
this is getting a bit grim guys.
tt steve
Steve, Bob is talking about the UK car, which needs a boost controller, your J-spec shouldn't.
Removing the cats on a UK Supra doesn't have the same effect, as removing them on a J-spec. On a UK Supra a boost controller is needed to raise the boost. On you J-spec removing the cats, will probably increase boost too much, which is why a restrictor ring in needed to bring the boost back down to a safe level.
i have just fitted both CW decat pipes and restrictor ring to my car
heres the story so far
i am now hitting .9 boost....my options are too increase the diameter of the restrictor ring to increase boost...in theory this seems good except that if i get the boost to 1.2 just now....when the cold weather comes along and i put the foot down...i could potentially see anything up to 1.5 with the dense cold air - definitely not good
2nd option is a boost controller as i can raise boost to a ceiling of 1.2 without it going higher...or should in theory!
the other option is as follows....get the first cat removed and fit an envy pipe - its about 3" diameter as opposed to CW 2 1/2"-....this raised my car to 1 bar with the 2nd cat still in- this also meant i still passed an MOT. I did however change the plugs as this small increase did mean i needed the platinum plugs (as described in a previous plug thread)
hope this helps
