Suprakeith Posted February 27, 2013 Share Posted February 27, 2013 As title says need new rear nearside upper arm. took car to to darren lee today for check over and have alot of play in rear nearside wheel rang toyota and part will cost £450 so was just wondering in any one on here can get cheaper parts? as last few months my supra has cost me a bomb and just want to see if can save myself some money before pay out that for part. Link to comment Share on other sites More sharing options...
trebor69 Posted February 27, 2013 Share Posted February 27, 2013 jjs82 can get a pair of new oem arms for £450. I have just probushed mine and I would defo recommend this, handles great now, pro bushes from paul whiffin around £100 ish delivered . Link to comment Share on other sites More sharing options...
Suprakeith Posted February 27, 2013 Author Share Posted February 27, 2013 Thank you will give him a PM Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 27, 2013 Share Posted February 27, 2013 If you get stuck, by far my best selling fix for this issue is the Superpro rear upper arm bushes, about £105 for both sides. In stock if required. Link to comment Share on other sites More sharing options...
Paul372 Posted February 27, 2013 Share Posted February 27, 2013 I can vouch for that, I did mine and few years ago, got the bushes from Paul Link to comment Share on other sites More sharing options...
mattdavies Posted February 27, 2013 Share Posted February 27, 2013 These bushes going a common thing ? I have knocking at the rear and i have changed the ARB bushes and Drop links but still there knocking persists Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 27, 2013 Share Posted February 27, 2013 These bushes going a common thing ? I have knocking at the rear and i have changed the ARB bushes and Drop links but still there knocking persists Yes, we repair loads of them here Link to comment Share on other sites More sharing options...
mattdavies Posted February 27, 2013 Share Posted February 27, 2013 Replacement - old ones pressed out and new ones pressed in ? OR can i do it on my Driveway ? Link to comment Share on other sites More sharing options...
trebor69 Posted February 27, 2013 Share Posted February 27, 2013 Replacement - old ones pressed out and new ones pressed in ? OR can i do it on my Driveway ? Old ones need pressing or even cutting out ......refitting superpro is easy and by hand. Link to comment Share on other sites More sharing options...
mattdavies Posted February 27, 2013 Share Posted February 27, 2013 Old ones need pressing or even cutting out ......refitting superpro is easy and by hand. Hacksaw ok ? Link to comment Share on other sites More sharing options...
Suprakeith Posted February 27, 2013 Author Share Posted February 27, 2013 Like the sound of them superpro bushes paul, like above do have press out old ones ad new ones in? Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 27, 2013 Share Posted February 27, 2013 Like the sound of them superpro bushes paul, like above do have press out old ones ad new ones in? You'll need a press. Link to comment Share on other sites More sharing options...
Slicknick Posted February 27, 2013 Share Posted February 27, 2013 Hacksaw ok ? Did mine in the driveway, hardest part was removing the bushes, used a whole cutter to remove the rubber inner then a hacksaw to remove the steal collar inside. As stated fitting the poly bushes is press fit by hand p.s. mine were completely shot but never knocked. Link to comment Share on other sites More sharing options...
trebor69 Posted February 28, 2013 Share Posted February 28, 2013 Hacksaw ok ? Pressing them out would be the best bet but you need a socket the exact size so as not to damage the arm (think its between 33 and 34mm), hacksawing them out is another route but remember that you are cutting the steel from Aluminium and you will have to be very careful, I was stuck for time so took them to a friend/garage and let him cut them out . Link to comment Share on other sites More sharing options...
trebor69 Posted February 28, 2013 Share Posted February 28, 2013 Mine were also well knackered but never knocked, just made the car wander . Link to comment Share on other sites More sharing options...
Guest aspire Posted February 28, 2013 Share Posted February 28, 2013 Hacksaw ok ? check your sub frame bolts first Link to comment Share on other sites More sharing options...
Suprakeith Posted February 28, 2013 Author Share Posted February 28, 2013 Mine is knocking when go over bumps and pot holes, plus when turn right it sounds like something rubbing. Link to comment Share on other sites More sharing options...
Suprakeith Posted March 1, 2013 Author Share Posted March 1, 2013 Have had car up on ramp and found that not only is the top bush badly damaged also the balljoint has alot of play compared to other side so will need the full upper rear arm kit from toyota to sort problem so thats a nice £450 out of na-t savings But at least car will be sorted and hopefully the overtime will continue at work so can build na-t fund back up asap Link to comment Share on other sites More sharing options...
Iky Posted March 1, 2013 Share Posted March 1, 2013 Have had car up on ramp and found that not only is the top bush badly damaged also the balljoint has alot of play compared to other side so will need the full upper rear arm kit from toyota to sort problem so thats a nice £450 out of na-t savings But at least car will be sorted and hopefully the overtime will continue at work so can build na-t fund back up asap Thats the best way chap. handling should always prioritise over power. Power is no good if the car handles like poo Link to comment Share on other sites More sharing options...
Suprakeith Posted March 1, 2013 Author Share Posted March 1, 2013 Thats the best way chap. handling should always prioritise over power. Power is no good if the car handles like poo Thats exactly what i thought car needs to handle well and be in good condition before think of power Link to comment Share on other sites More sharing options...
