Radiator
Steve Gee
Thanks for the info guys.
Has anyone had experience of replacing the rad?
I know these things have a habit of becoming harder than they look!!
Is there really that much difference in rad performance?
How many degrees difference are we talking, 10-15?
The stock can't be that bad can it!?!?!
Thanks
Steve
Quote: from Steve Gee on 8:56 am on Feb. 14, 2002[br]Thanks for the info guys.
Thanks
Steve
I don't think it's a matter of the stock rad being bad, but if you can get a better one for around the same money why not.
Guest Terry S
Sorry should also have said that the Fluidyne is all ali. The reason I changed was that my kenlowe switch failed on the electric fan kit & the stock rad plastic header turned into a grenade.
You could get a radiator which is more efficient than the fluidyne which could allow you to run a smaller radiator....but as efficiency goes up so does cost.
I mention this as you could stack an ultra efficient rad and an ultra efficient intercooler one on top of the other. Making packaging easier reducing the weight infront of the front wheels (any weight futher forward than the front axle line is not helpful for switching direction).
Just a thought.....
Alex , do you have any cost effective solutions :biggrin:
I definately don't want another radiator up front .... Was thinking more of a small air to air cooler in one of the side intakes
i have a FMIC and don't need anything else behind the small stock air intake
Is this feasible or advisable ?
The Toyota option sounds the simplest :(
Hi Guys,
New Rad ordered, not here 'til Tuesday though!
Car now sits very folornly on the drive. :-(
I'm going to take the rad out today.
Can anyone give me any tips/advice?
How many bolts, where are they, what else needs to come out???
Any advice would be most welcome.
Cheers
Steve
