Exhaust technical help
scott87
Im hopefully buying a new manifold form a member on here but i just wanted to check a few things first. Currently i have the standard backbox, both silencers under the car deleted and a 3" 2nd decat. The manifold obviously deletes the first cat, by question is will i loose too much back pressure, or because i have the stock diameter pipe it should be ok?
Also ignore the arb, on the list of things to be repaired!
This is the current setup on my car.
