Andrew K Posted February 23, 2013 Share Posted February 23, 2013 What do I do with these 2 pipes I'm holding in the picture below? I'm going to fit a single turbo setup and the inlet side is Staying stock so when you follow these back round to the inlet side they all join up where there Supposed to but obviously not on the turbo side any more? https://jza80.mkivsupra.net/imports/2013/02/722.jpg[/img]"] Quote Link to comment Share on other sites More sharing options...
heckler Posted February 23, 2013 Share Posted February 23, 2013 either remove them or just pull the hose off and leave them - which is what I did Quote Link to comment Share on other sites More sharing options...
Andrew K Posted February 23, 2013 Author Share Posted February 23, 2013 either remove them or just pull the hose off and leave them - which is what I did Will that stop anything from working as it should on the intake side? Would it hurt to join the 2 pipes I'm holding together, making it a 'U' bend? Quote Link to comment Share on other sites More sharing options...
heckler Posted February 23, 2013 Share Posted February 23, 2013 Will that stop anything from working as it should on the intake side? Would it hurt to join the 2 pipes I'm holding together, making it a 'U' bend? nope, as they were connected to the pressure tank underneath the inlet manifold. As you going single the pressure tank serves no purpose Quote Link to comment Share on other sites More sharing options...
Andrew K Posted February 23, 2013 Author Share Posted February 23, 2013 nope, as they were connected to the pressure tank underneath the inlet manifold. As you going single the pressure tank serves no purpose Ok thanks so I can do away with the pressure tank then? What happens from the pressure tank back up to the inlet as they route of from the pressure tank to the inlet? Quote Link to comment Share on other sites More sharing options...
Mugello Posted February 23, 2013 Share Posted February 23, 2013 They are the feed to and from the stock pressure tank needed for the stock twins. Not needed when going single. Bin it all imo. Quote Link to comment Share on other sites More sharing options...
heckler Posted February 23, 2013 Share Posted February 23, 2013 Ok thanks so I can do away with the pressure tank then? What happens from the pressure tank back up to the inlet as they route of from the pressure tank to the inlet? yup, bin that too. tank is there for the sequential system for activation of various VSV's Quote Link to comment Share on other sites More sharing options...
