ronttuk Posted February 21, 2013 Share Posted February 21, 2013 Last night I drove the supra home turned it of as usual and the Ariel didn't retract . This morning I try to start it and its dead I find a loose battery terminal, so I put it back on start the car and its running rough seems to be over fueling or something. Any ideas or is it the ECU going through a learni.g phase again? Car is s UK spec 1994 auto Quote Link to comment Share on other sites More sharing options...
Tyson Posted February 21, 2013 Share Posted February 21, 2013 Last night I drove the supra home turned it of as usual and the Ariel didn't retract . This morning I try to start it and its dead I find a loose battery terminal, so I put it back on start the car and its running rough seems to be over fueling or something. Any ideas or is it the ECU going through a learni.g phase again? Car is s UK spec 1994 auto Pretty sure if the battery is disconnected the ECU gets wiped so has to relearn. Quote Link to comment Share on other sites More sharing options...
Abz Posted February 21, 2013 Share Posted February 21, 2013 Will be the ECU relearning... should sort itself out Ron. Just check oil and fluids are okay. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted February 22, 2013 Share Posted February 22, 2013 Yeah after it's run for a few mins and turned on and off it will be ok Quote Link to comment Share on other sites More sharing options...
ronttuk Posted February 22, 2013 Author Share Posted February 22, 2013 Thanks guys Quote Link to comment Share on other sites More sharing options...
