Clausz Posted February 20, 2013 Share Posted February 20, 2013 Hi All I need some help wiring my electric fans, so my HKS ECU will control the fans. As I could see in the specs for F-CON Pro V, this should be possible. I know that the fans needs a relay, and the current draw won't be directly from the ECU. Does anyone have knowledge about the HKS F-CON Pro V wiring diagram? Best Regards Claus Link to comment Share on other sites More sharing options...
Guest jag86 Posted April 27, 2013 Share Posted April 27, 2013 Yes, we have the diagram, which version of the HKS do you have? You will need to activate fan control by jumper setting in the ECU, put extra wire connection to the HKS ECU and set temperature control ON OFF by using PW. Link to comment Share on other sites More sharing options...
