Suprash Posted February 18, 2013 Share Posted February 18, 2013 So, I've seen blue and even a purple cam belt, but does anyone know if you can get a yellow cam belt ? Also, what about yellow cam gears ? I've spent about an hour so far searching Google images and cant find anything Is a VVT-i cam belt the same as a non VVT-i belt ? Quote Link to comment Share on other sites More sharing options...
Suprash Posted February 19, 2013 Author Share Posted February 19, 2013 No one Quote Link to comment Share on other sites More sharing options...
Josh42 Posted February 19, 2013 Share Posted February 19, 2013 If I'm correct ash, I think VVTI cam belts are different. Never come across a yellow belt before now but there may be one out there! Quote Link to comment Share on other sites More sharing options...
Scott Posted February 19, 2013 Share Posted February 19, 2013 Yellow cams shouldn't be too much of a problem but the colour of the belt generally depends on manufacturer colours. You would need to find a manufacturer who uses yellow as their "colour". EG HKS is purple, so their belts are purple, gates are blue so their belts are blue... etc. I was looking into getting a red belt, and while I did manage to find one it was an itchi-fannii make so I decided to just go with tried and tested. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 19, 2013 Share Posted February 19, 2013 If you supply a set of aftermarket pulleys i can get them anodised yellow. only seen Blue or purple cam belts and black stock belt obviously Quote Link to comment Share on other sites More sharing options...
Scott Posted February 19, 2013 Share Posted February 19, 2013 http://www.rainbowprecisionproducts.com/index.html These guys do yellow belts but whether they do the correct spec or not is the question. You could shoot them an email to see if they can help you out. Quote Link to comment Share on other sites More sharing options...
Suprash Posted February 19, 2013 Author Share Posted February 19, 2013 If I'm correct ash, I think VVTI cam belts are different. Never come across a yellow belt before now but there may be one out there! Are you correct ? I dunno mate, you tell me ??? If you supply a set of aftermarket pulleys i can get them anodised yellow. only seen Blue or purple cam belts and black stock belt obviously Do they have to be aftermarket pulleys, or could you get stock ones anodised, does it have to be a certain type of metal to be adonised ? http://www.rainbowprecisionproducts.com/index.html These guys do yellow belts but whether they do the correct spec or not is the question. You could shoot them an email to see if they can help you out. Thanks man, I have emailed these guys to see what they say Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 19, 2013 Share Posted February 19, 2013 Yeah has to be aluminium. Get the stock pulleys powder coated mate Quote Link to comment Share on other sites More sharing options...
