_Shane_ Posted February 14, 2013 Share Posted February 14, 2013 Well im going to tackle spraying my engine bay at the weekend, just looking for some advice on what parts should come out and if there is any particular ones that may give trouble when removing them etc I know a few of ye on here have done this on your own supra's so im asking if there is anything i should be careful with etc etc Any advice appreicated Thanks Link to comment Share on other sites More sharing options...
ashbuster Posted February 14, 2013 Share Posted February 14, 2013 are you rattle canning it mate for spraygun? Link to comment Share on other sites More sharing options...
_Shane_ Posted February 14, 2013 Author Share Posted February 14, 2013 mask / prep / spraygun I have pretty much everything on the driver side removed that would need to be removed Im really asking about passenger side (fuse box), can i delete the charcoal cannister at the rear etc? Link to comment Share on other sites More sharing options...
ashbuster Posted February 14, 2013 Share Posted February 14, 2013 if it was me mate and it was being done with a spray gun properly then best to move as much as possible. from what ive read the fuse box can be fitted under the headlight without cutting and extending wires so maybe you can remove it and put it somewhere underneath out of the way untill its been sprayed. i would remove as much as possible like the charcoal canister can come out and if you want to put it back in you can always re-fit it afterwards. battery to boot /fusebox relocation/ wiretuck and smoothing not interest you mate? Link to comment Share on other sites More sharing options...
_Shane_ Posted February 14, 2013 Author Share Posted February 14, 2013 battery already in boot mate, wire tuck would be good but dont think anyone over here is capable of doing this properly lol Do you know how easy / hard it would be to remove fuse box or even just give me some slack so i can have it out of the bay while spraying is been done etc Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 14, 2013 Share Posted February 14, 2013 charcoal canister can go in the bin mate Link to comment Share on other sites More sharing options...
_Shane_ Posted February 14, 2013 Author Share Posted February 14, 2013 what about the lines coming off it? So far headlights removed, over flow bottle, top neck of window washer tank, battery gone to the boot. Main thing now is fuse box how can i relocate fuse box without need to extend the wires does anyone know? Link to comment Share on other sites More sharing options...
ashbuster Posted February 14, 2013 Share Posted February 14, 2013 i will be doing this myself soon, just havent had the weather here, the snow has only just cleared up. i was under the impression the fuse box can be put under the light without extending wires, im sure rob did it with his in his build thread. ill have a look bud edit*** link bud http://www.mkivsupra.net/vbb/showthread.php?236276-Gold-Rush/page57 also link to the charcoal canister delete http://mkiv.com/tmp/no_charcoal_canister/index.html Link to comment Share on other sites More sharing options...
_Shane_ Posted February 14, 2013 Author Share Posted February 14, 2013 I was told ya had to extend the ABS and the A/c wires if moving fuse box under passenger headlight Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 14, 2013 Share Posted February 14, 2013 One problemo with under the headlight is condensation and water getting into the box... mine is now behind my rear seats! pukka Link to comment Share on other sites More sharing options...
ashbuster Posted February 14, 2013 Share Posted February 14, 2013 i was thinking of putting mine where the charcoal canister is and make a smaller box for it, that way its still hidden when i buy the srd enginebay boxes and still easy to get to without extending much Link to comment Share on other sites More sharing options...
hodge Posted February 14, 2013 Share Posted February 14, 2013 charcoal canister can go in the bin mate aaaaaaamen to that brother. Link to comment Share on other sites More sharing options...
_Shane_ Posted February 14, 2013 Author Share Posted February 14, 2013 So i can just disconnect charcoal cannister and dump it in the bin? what about the hoses connected to it guys Link to comment Share on other sites More sharing options...
hodge Posted February 14, 2013 Share Posted February 14, 2013 So i can just disconnect charcoal cannister and dump it in the bin? what about the hoses connected to it guys There's 3 pipes, 1, runs around the back of the engine to the turbo pipes, odviously you won't have that 1. 2, is a petrol tank breather, disconnect that and bend it down under the car to vent. 3, is a vacum pipe which runs along the side of the intake manifold and T's into the intake at the front. Disconnect that, at the manifold and join the pipes up. Link to comment Share on other sites More sharing options...
_Shane_ Posted February 14, 2013 Author Share Posted February 14, 2013 Thanks John Link to comment Share on other sites More sharing options...
ashbuster Posted February 14, 2013 Share Posted February 14, 2013 i read somewhere that it lowers the pressure in the fuel tank and can make the fuel pump play up. is this right bud? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 14, 2013 Share Posted February 14, 2013 i read somewhere that it lowers the pressure in the fuel tank and can make the fuel pump play up. is this right bud? Charcoal canister you on about? Just absorbs fuel vapour, not really needed mate Link to comment Share on other sites More sharing options...
ashbuster Posted February 14, 2013 Share Posted February 14, 2013 yes mate something about removing the positive pressure in the fuel tank when the charcoal canister is deleted. is this nothing to worry about? Link to comment Share on other sites More sharing options...
hodge Posted February 14, 2013 Share Posted February 14, 2013 yes mate something about removing the positive pressure in the fuel tank when the charcoal canister is deleted. is this nothing to worry about? It doesn't need the canister as Rob says. Link to comment Share on other sites More sharing options...
ashbuster Posted February 14, 2013 Share Posted February 14, 2013 nice one guys Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 14, 2013 Share Posted February 14, 2013 yes mate something about removing the positive pressure in the fuel tank when the charcoal canister is deleted. is this nothing to worry about? No don't worry, everyone Bins them. Just make sure you route the pipe that goes into the bay to the canister,out of the bay.... Stops the smell of petrol Link to comment Share on other sites More sharing options...
ashbuster Posted February 14, 2013 Share Posted February 14, 2013 ok bud, just put it pointing towards the rear/road under the car should be fine? the one from the tank to vent underneath and then just block the other pipes? sorry for the high jack shane Link to comment Share on other sites More sharing options...
hodge Posted February 14, 2013 Share Posted February 14, 2013 ok bud, just put it pointing towards the rear/road under the car should be fine? the one from the tank to vent underneath and then just block the other pipes? sorry for the high jack shane Yep that's correct. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 14, 2013 Share Posted February 14, 2013 ok bud, just put it pointing towards the rear/road under the car should be fine? the one from the tank to vent underneath and then just block the other pipes? sorry for the high jack shane Yeah blood Link to comment Share on other sites More sharing options...
ashbuster Posted February 14, 2013 Share Posted February 14, 2013 thanks guys Link to comment Share on other sites More sharing options...
