Headlights
Guest Dannyboy
Guest Dannyboy
Hi guys
Sorry If this is a repost iv had a look but only on a iPhone and couldn't see anything about it
What headlight bulbs actually fit into a import? I need some for MOT
Any advice would be Seriously aprichiated
If you look on the lens it says hb3 and hb4. I bought as stated on the lens, but couldn't fit the hb4's. I came to the conclusion that they are both hb3's. Best way to check for fit is by taking the headlight unit from the car.
There are plenty of sellers on fleaby that can provide you with a complete set of lights. eBay item 330707472616 should do the trick!
Steve
Cheers guys iv bought hb4s and they don't fit and HB3 they go into the slots but don't turn to lock in :/ il have a look on eBay
Cheers again
If you have j-spec headlight (with plastics lenses) then you need to use 9005/HB3 in the high and low beam, they will turn and lock but take a bit of fiddling with, if you can't get them to fit remove the plastic collar on the back of the headlights where the bulb tabs fit into they are held in with 3 small screws. You will also need to remove the rib on the wiring connector so the plug fits. Do a search in FAQ section for '9005' for full explanation.
