Jake Posted August 15, 2005 Share Posted August 15, 2005 . . . or are they? I have just stripped down the turbos from my blown engine. (When I say 'stripped down' I mean unbolted them from the cast iron turbine outlet manifold thing, not actually stripped the turbos themselves.) I was expecting to see damaged blades on the hot side but actually the turbine wheels look to be in perfect condition. Same with the impeller blades on the compressor side. Does this mean they probably didn't need changing? It would be an unexpected bonus if it meant I had a spare set of 36,000 miles turbos. I might even stick 'em on my smokey old RZ if you guys think they're probably ok. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted August 15, 2005 Share Posted August 15, 2005 shaft movement? Quote Link to comment Share on other sites More sharing options...
Jake Posted August 15, 2005 Author Share Posted August 15, 2005 None 'in and out', a millimeter or two from side to side - same as the 'new' ones I replaced them with. I hope that's how they're suposed to be. Quote Link to comment Share on other sites More sharing options...
Scarface GTti Posted August 15, 2005 Share Posted August 15, 2005 If there`s any thrust movement (forwards and backwards) they`re trollied. Quote Link to comment Share on other sites More sharing options...
Scarface GTti Posted August 15, 2005 Share Posted August 15, 2005 Oops too slow. They sound o.k though. Quote Link to comment Share on other sites More sharing options...
Jake Posted August 15, 2005 Author Share Posted August 15, 2005 That would be nice. I wonder if I can get them checked somehow. (Other than putting them on and seeing ) Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted August 15, 2005 Share Posted August 15, 2005 yes mate sounds like nothing went through them so you are probably good to go Quote Link to comment Share on other sites More sharing options...
Jake Posted August 15, 2005 Author Share Posted August 15, 2005 Quote Link to comment Share on other sites More sharing options...
Scarface GTti Posted August 15, 2005 Share Posted August 15, 2005 You could give them to me and i`ll try them for 6 months on my Daihatsu Quote Link to comment Share on other sites More sharing options...
Miguel Posted August 15, 2005 Share Posted August 15, 2005 If all the above is ok and there are no show of oil weapage on the seals ..then they sound OK ..realy hard to diagnose without seeing them in the flesh . Quote Link to comment Share on other sites More sharing options...
Jake Posted August 15, 2005 Author Share Posted August 15, 2005 I think oil weapage would be difficult to diagnose because every single internal part was drenched in oil from when the engine went pop. The intake was full of oil, the intercooler was full of oil, the IC piping, the exhaust, you get the idea. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted August 15, 2005 Share Posted August 15, 2005 I think oil weapage would be difficult to diagnose because every single internal part was drenched in oil from when the engine went pop. The intake was full of oil, the intercooler was full of oil, the IC piping, the exhaust, you get the idea. Was there any oil when she blew Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 15, 2005 Share Posted August 15, 2005 Roy had the ones on my car taken off and bench tested when he had that smoke problem (the one that turned out to be an overfilled auto box). I can have a look through the receipts and see who did them if you like. And dood I had a set of turbo's you could have had if I'd have seen your post in time Quote Link to comment Share on other sites More sharing options...
CJ Posted August 15, 2005 Share Posted August 15, 2005 I recently dealt with a company in Christchurch called Turbo Dynamics. They were very good and very quick too. I am sure they can test them for you. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 15, 2005 Share Posted August 15, 2005 I recently dealt with a company in Christchurch called Turbo Dynamics. They were very good and very quick too. I am sure they can test them for you. Thats just down the road as well mate Quote Link to comment Share on other sites More sharing options...
Jake Posted August 15, 2005 Author Share Posted August 15, 2005 Cheers CJ, I might give them a ring. Thanks anyway Bry. Was there any oil when she blewNot quite sure what you mean Terry. When the engine blew up there was a massive cloud of oil smoke but no smoke before that point. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 15, 2005 Share Posted August 15, 2005 Cheers CJ, I might give them a ring. Thanks anyway Bry. Not quite sure what you mean Terry. When the engine blew up there was a massive cloud of oil smoke but no smoke before that point. Hey you heckler I just noticed your membership is due ha ha lol Quote Link to comment Share on other sites More sharing options...
Ian C Posted August 15, 2005 Share Posted August 15, 2005 Hey you heckler I just noticed your membership is due ha ha lol Hook line and sinker That's Jake's custom avatar text... -Ian Quote Link to comment Share on other sites More sharing options...
Jake Posted August 15, 2005 Author Share Posted August 15, 2005 Thanks for playing Bry! Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted August 15, 2005 Share Posted August 15, 2005 Quote Link to comment Share on other sites More sharing options...
CJ Posted August 15, 2005 Share Posted August 15, 2005 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 16, 2005 Share Posted August 16, 2005 The only ways to test a used turbo for seal wear is either strip it and look / measure, or bang it on an engine and run it. Gotta be teted hot with the real life pressure variations across it, or a phsical examination, in other words. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 16, 2005 Share Posted August 16, 2005 are, s, y. Add in relevant spots, too much beer at a friends last night.... Quote Link to comment Share on other sites More sharing options...
