Mariusz Posted February 10, 2013 Share Posted February 10, 2013 I cleaned the Supe today and tried some TFR ( Tarmac film remover ) , , came up real nice! Seems to be good stuff!! Not sure if its good for long term / frequent use. Anyone else used this? Quote Link to comment Share on other sites More sharing options...
shaz2010 Posted February 10, 2013 Share Posted February 10, 2013 I use it on my alloys but never used it on the paint work ! I don't think it should be left on the paint for to long am sure it can damage it Quote Link to comment Share on other sites More sharing options...
Mariusz Posted February 10, 2013 Author Share Posted February 10, 2013 (edited) The TFR was mixed in a solution in the spray cleaner and jet washed straight off. Deo won't be using this regularly as i'm sure it would cause the paint to fade. Used as a one off to get rid of all the grime. I'm sure it will be fine. Edited February 10, 2013 by Mariusz (see edit history) Quote Link to comment Share on other sites More sharing options...
FOSTA Posted February 10, 2013 Share Posted February 10, 2013 I use it on my alloys but never used it on the paint work ! I don't think it should be left on the paint for to long am sure it can damage it Yep, I used a morrisons car wash and I ran out of time and had to go and pay for more, by the time I came back out the sun had dried the TFR on my paintwork and after a wash down and rince off it had bleached the paintwork/ clear coat. I tried to polish it out but with no luck. I think If I got it detailed it most likly would of polished out but I just ended up getting it mostly re-sprayed anyways to freshen the car up Quote Link to comment Share on other sites More sharing options...
peter richards Posted February 10, 2013 Share Posted February 10, 2013 only ever use it on the lower panels , spray it on and PW off , dont leave it and on hot days better off not using it , if it dries its a pita plus it will streak Quote Link to comment Share on other sites More sharing options...
Mariusz Posted February 10, 2013 Author Share Posted February 10, 2013 Won't be using that again Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 10, 2013 Share Posted February 10, 2013 I have just bought autosmarts TFR and they tell me its fine to use on any part of a car. I imagine like most things there's good and bad so you can't really generalise as not all TFR's will be the same Quote Link to comment Share on other sites More sharing options...
Mariusz Posted February 10, 2013 Author Share Posted February 10, 2013 I have just bought autosmarts TFR and they tell me its fine to use on any part of a car. I imagine like most things there's good and bad so you can't really generalise as not all TFR's will be the same good point there! Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 10, 2013 Share Posted February 10, 2013 Most of your cheap £5.00 car wash uses TFR and for that reason alone and a few other reason I never use those cheap car washes. Also I guess it depends on your ratio when mixing TRF and water. But I guess like anything be cautious on using certain car prodcuts. Quote Link to comment Share on other sites More sharing options...
