Royal purple LSD diff oil and v160 oil
Guest Malachi
Guest Malachi
in the Supra manual it says
Differential Oil 1.35 liters (1.43 US qts, 1.19 lmp. qts)
API GL–5
Above–18° C (0° F)
SAE 90
Below–18° C (0° F)
SAE 80W–90 or 80W
So its okay to use Royal Purple max gear 75w90 for Diff and royal purple synchromax for the V160gear box?
please confirm those for me , so I can go ahead and buy them cheers
Edited by Malachi (see edit history)
http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine
Have a look in the oil reference guide,
LSD Diff Oil
Stock = Unknown 75w90 Gear Oil
Capacity ~1.5L's (have 2L's Ready)
75w90 - Motul Gear 300 or Silkolene Syn5
I recommened either of the two listed - both have been used without issue.
Interval = 2 Years / 30,000miles depending on use/power levels
See here for details on changing diff oil.
Manual 6-speed V160/161 Gearbox
Stock = Toyota V160 oil (PART No. 08885-01306)
Capacity 1.8l's when dry
Toyota V160 Oil (comes in 1L cans - require 2 cans)
Alternative:
Esso Dextron D21065
Royal Purple SynchroMax
BMW oil called MTF-LT-1 or LT-2
Castrol Transmax Z - Feedback required from testers
Mobil ATF 220 - Feedback required from testers
I recommend you stick with stock but in recent times this has been hard to get hold of, so it's the Esso now...
