Hks f-con s?
RB-GTE
So today I was installing my Walbro 255 to only find out I already had a Walbro.
Then I was about to install my HKS FCD to only find out I have a HKS F-CON S?? that's an unexpected surprise.
THEN I also found out I had 550cc Injectors... a bunch of surprises. I didn't know my car had these things.
I did some research and I'm trying to figure out what the HKS F-CON S actually does, and some of the features.
Is this a MAP based ECU piggyback?
because its attached to my stock ECU, wired into the harness.
My TT is basically BPU right now. Is this also suiteable for a single turbo setup? :)
Any links on information I could reach about it?
cheers!
Edited by RB-GTE (see edit history)
cheers!
http://members.ziggo.nl/renima/fcon.jpg
I had this in my gtr. Its really only a stage 1/2 piggyback ecu or bpu for the supra. If your going single then I'd ditch it. Not many people can map them either
Yep my mechanic also said there is a good chance I might be running upgraded cams as well! I'll have to pull the cam covers off and take a look.
But anyways, the car idles low often and it has a very rough start on cold start. I'll figure out tomorrow if we can find anyone locally to tune/map it (I don't live in the UK btw).
