Squeal as the car comes on to positive boost?
letmeshowyou
Hi All,
So, I had the car double decatted at Whifbitz on Friday, to bring the car up to full BPU (TT Auto), and since leaving Paul's, the car has developed a really annoying squeal just as it comes in to positive boost, which starts at 0, and goes away again by the time it's reached about 0.2-0.3. Anyone any suggestions on what this might be?
A few of the bluewater lot came out in the car Friday night, and I'd initially come to the conclusion that it was the fan belt (it sounds like a belt slip squeal), however the noise is still present having changed this for a new one. Darren had a bit more dis-assembled than originally intended due to a stud snapping on the downpipe, however it sounds more like a rotational squeal than a loose heatshield.
There was an initial suggestion that it might be a turbo on it's way out, but I'm not convinced on this for the following reasons:
1) it wasn't doing it before
2) the noise goes away above about 0.3bar
3) I'd imagine the turbo to be spinning at quite reasonable RPM's as it approaches positive boost, and yet the noise isn't present before
4) the squeal doesn't seem as high pitched as I'd expect it to be assuming high turbo RPM's at the boost threshold
5) it pulls very, very well now
I did consider converting to TTC temporarily to see if it went away; does this seem like a good idea to anyone else?
Squeal on boost = leak in a pipe from the turbos to the manifold, check all the clamps, and check them well.
:yeahthat: pop over at the weekend if you want a hand finding it.
I have a compressor, maybe we can blow some air in to try and find it?
That guy just kept going round a roundabout until I got to it (you had already passed over it) then he saw me followed about an inch away from my bumper!
But made sure he knew the difference between a Fiesta ST and a Supra TT BPU, let him get really close on the M69 slip road then my foot was flat to the floor... he was a spec in the mirror ;)
Then just to add to his insult I'd slowed off and he started catching up, his mate waved and mouthed bye, so I went yeah see ya, foot to the floor again and shot past him :D
Childish i know lol
Edited by Littler (see edit history)
