Changing rear brake discs
Supra Ems
Hi,
I'm sure this is on the site somewhere but am having trouble finding it! Is a step by step guide to changing my rear discs available? Have done it on other cars before but not sure how easy it is on the Supra. Mine has the bigger brake set-up if that makes any difference.
Grateful for any help.
Thanks!
Read from page BR-45
Take the wheel off, ease the pads apart in the caliper, undo the 2 bolts
that hold the caliper to the hub then slide the caliper off the disc and
cable tie it out the way.
Slacken off the handbrake adjuster and remove
the bolts that locate the disc to the hub then wriggle the disc off.
BR.pdf
Undo the small nut on the caliper, slide the arm up and remove the pads. Tie the slide calliper section up, then unbolt the calliper mount and remove.
Then the disk is free to be removed, just make sure you dont have the handbrake on.
Ive always managed to gently tap the disk off but through the small hole there is an adjuster for the hub brake to release them from the disk if you struggle.
Or Follow that guide i couldn't find! :innocent:
lmao
Fronts are dead easy as there's no handbrake to worry about.
Wheel off, ease pads apart in caliper, undo the 2 caliper
mounting bolts and cable tie it out the way
undo the securing bolt/s holding the disc to the hub
remove disc
make sure the new discs mating faces are clean same
goes for the hub
brake cleaner from Halfords in a spray tin is very useful
to wipe over the parts before assembly.
Oh and check the discs as they are handed Left and Right due to the
way the ventilated veins run. There is an L and an R cast into
the o/e discs.
The discs could have delivery rustproof/grease on them
so remove with brake cleaner,
DO NOT USE WD40 !!!!
Re fit caliper and do up the bolts properly, same goes for
the wheel nuts
