Fly Posted July 8, 2013 Author Share Posted July 8, 2013 Just a quick update, I sourced a fitting kit to install my new fpr and delete the fuel pulsation damper at the same time. Hopefully that should be here by the weekend. I have also just purchased a stage 4 six puck competition clutch as it seemed a good deal, however I am now reading that you must use it with a competition flywheel annoying so have to source one of those now!! Will update properly once the fpr is on and see if I can solve the lack of fuel in the engine Link to comment Share on other sites More sharing options...
listy Posted July 8, 2013 Share Posted July 8, 2013 I have a stage 4 CC on mine with a stock flywheel. Never had a problem. Link to comment Share on other sites More sharing options...
Fly Posted July 8, 2013 Author Share Posted July 8, 2013 I have a stage 4 CC on mine with a stock flywheel. Never had a problem. Six speed or five though? Link to comment Share on other sites More sharing options...
listy Posted July 8, 2013 Share Posted July 8, 2013 5 speed mate. Link to comment Share on other sites More sharing options...
Rich.2211 Posted July 8, 2013 Share Posted July 8, 2013 Hi mate, where is the clutch from? I need one! Link to comment Share on other sites More sharing options...
Fly Posted July 14, 2013 Author Share Posted July 14, 2013 Rich, replied via pm. Hi guys well at long last I have solved my under fuelling issue. I fitted an aeromotive fuel pressure regulator on advise from Austec racing, I also fitted a fuel pulsation damper whilst I was at it. Set the rail pressure for 3 bar and took her out . I now am massively overfuelling which can be solved. As soon as we hit boost the afrs go down to 8s , massively rich. You may be thinking why is this good but atleast I can get more boost/air in and map out some fuel. The mot is up this month so the little jobs I've been putting off need doing. Need to get my fog light mod from heckler installed and get power to my electric seat . I rigged it up and the back adjusts but forward/backward just makes noise ,Need to check it out further . Needless to say I'm chuffed to bits that's she's getting there Link to comment Share on other sites More sharing options...
Rich.2211 Posted July 14, 2013 Share Posted July 14, 2013 Rich, replied via pm. Hi guys well at long last I have solved my under fuelling issue. I fitted an aeromotive fuel pressure regulator on advise from Austec racing, I also fitted a fuel pulsation damper whilst I was at it. Set the rail pressure for 3 bar and took her out . I now am massively overfuelling which can be solved. As soon as we hit boost the afrs go down to 8s , massively rich. You may be thinking why is this good but atleast I can get more boost/air in and map out some fuel. The mot is up this month so the little jobs I've been putting off need doing. Need to get my fog light mod from heckler installed and get power to my electric seat . I rigged it up and the back adjusts but forward/backward just makes noise ,Need to check it out further . Needless to say I'm chuffed to bits that's she's getting there I'm chuffed for you mate. I've received my fuel dampener delete from Hodge too, nice bit of kit I've solved my oil return problem by the way! Link to comment Share on other sites More sharing options...
Fly Posted July 14, 2013 Author Share Posted July 14, 2013 How did you manage it? Link to comment Share on other sites More sharing options...
Rich.2211 Posted July 14, 2013 Share Posted July 14, 2013 How did you manage it? I trimmed the flange on the turbo a little. Only enough for it to match the flange on the manifold but it was enough for it to fit Link to comment Share on other sites More sharing options...
Noz Posted July 15, 2013 Share Posted July 15, 2013 You going to go for a remap then Nick at some point? I would definitely adjust the tuning yourself for now. 10 is the lowest you should go on fueling map. And that's considered too much fuel in most applications. You can't drive on 8, that's insane. Super good news though. Well pleased for you. I'm coming up corby end of the month if your about? Link to comment Share on other sites More sharing options...
Fly Posted July 15, 2013 Author Share Posted July 15, 2013 Noz, yea i can feel her stutter as the cylinders are flooding with fuel, its soon as we hit 3k or boost. Im going to get the fog,seat and MOT sorted then continue to map her on the road. Ile get booked into Austec later on. But yea super good news atleast i have a starting point , i also sorted the map trace issue. Link to comment Share on other sites More sharing options...
Fly Posted July 22, 2013 Author Share Posted July 22, 2013 (edited) Yes!!!!!! All sorted today, set my boost controller up after fitting the fog and rebuilding my electric seat. On a separate not huge thanks to marksupra who produce a gear for me seat motor gearbox literally built it the same day he got the old one and had it back to me. So I ave working electric seats!!!!!! Anyway doi set up my boost not roller and reset my fuel pressure as it had dropped a little. Took her out boosting to 12 psi and all I can say is wow.....she screams and goes like a rocket....I have no Idea th current figures but she's awesome serious smile on your face territory.only minor problem is the stock six speed clutch is nt man enough, so waiting on my light weight flywheel to fitmy new clutch then hopefully the power should be right there! It's taken enough time coming but she's developing into a brilliant car maybe not everyone's cup of tea but she's ace. Now to meet to meet sone people,I've been annoyed tht the car as taken longer than expected and kept e away from a few meets. I would post up a vid but it shows the speedo which is not ideal....needles to say my eyes were fixed on the road and not the speedo!! This is not txt speak merely the inability to type on my iPad Edited July 22, 2013 by Fly (see edit history) Link to comment Share on other sites More sharing options...
Suprakeith Posted July 22, 2013 Share Posted July 22, 2013 Congrats mate, pleased you happy and enjoying car, its a great build Link to comment Share on other sites More sharing options...
Rich.2211 Posted July 22, 2013 Share Posted July 22, 2013 Hey mate, that is GREAT news!! Link to comment Share on other sites More sharing options...
markssupra Posted July 22, 2013 Share Posted July 22, 2013 Great news Nick, glad you received the gear back ok. Link to comment Share on other sites More sharing options...
Fly Posted July 23, 2013 Author Share Posted July 23, 2013 (edited) Yea thanks mark. I installed and then found that the other side was gone too as only one rail moved so I just removed the linkage and the winder to allow the other rail to just slide. I don't understand why people replace the whole frame when it's easy to replace the gear. Edit : made no sense as usual . Phone + fat fingers Edited July 23, 2013 by Fly (see edit history) Link to comment Share on other sites More sharing options...
Noz Posted July 23, 2013 Share Posted July 23, 2013 Good news. The video looked sweet last night. How did you sort the map trace? Link to comment Share on other sites More sharing options...
Fly Posted July 23, 2013 Author Share Posted July 23, 2013 There was another tick box hidden away in the parameters section. Big in trace but another tab I will have to look at the software to find exactly what it's called. However I do think there may be an underlying issue with the fuel pump as setting 3 bar static pressure results in it eventually falling to one bar at idle after a run. However if I set the static pressure to 4-4.5 bar after a run at idle it sits at 3bar. I may be misunderstanding how the fpr works but this sounds like a pump issue. To add I have also removed the charcoals canister to make some room in the bay for a little tank of goodness Link to comment Share on other sites More sharing options...
Kaan W Posted July 23, 2013 Share Posted July 23, 2013 Good progress so far mate, keep the updates coming your getting there! Link to comment Share on other sites More sharing options...
WaLKeRR Posted July 23, 2013 Share Posted July 23, 2013 So this spike at about 3500 is due to a crap map or crap fueling or this hidden parameter section ? im lost! lol Link to comment Share on other sites More sharing options...
Fly Posted July 24, 2013 Author Share Posted July 24, 2013 Spike? Are you talking about the lean running conditions ? Link to comment Share on other sites More sharing options...
WaLKeRR Posted July 24, 2013 Share Posted July 24, 2013 yeh the lean section because i had the same issue at 3000 ish rpm reading 14s on afr goes 11 14 11 if that makes sense then goes full boost perfectly all the way up the revs, fuel systems stock on the car also your emansge blue also arent you? Link to comment Share on other sites More sharing options...
Fly Posted July 25, 2013 Author Share Posted July 25, 2013 I'm running emanage ultimate. My spike , and I'm pretty convinced now was coming from low fuel pressure and not getting enough fuel over 3k. If you are getting a spike but then the afrs go back down to normal I would look at adding fuel in that part of the map. Does the spike also happen at wot or mid throttle and what boost pressure are you running at 3k rpm? Link to comment Share on other sites More sharing options...
WaLKeRR Posted July 25, 2013 Share Posted July 25, 2013 right im using blue, and isnt that part of a closed loop accoding to the mapper? he couldnt change that part? and only happens if i say.am full throttle from 2k and when i hit 3kish i spike and then it clears and goes full boost if i part throttle it passes it and possibly 3psi? Link to comment Share on other sites More sharing options...
Fly Posted November 15, 2013 Author Share Posted November 15, 2013 Right just a little update. I haven't updated this thread in a while mainly because I was quite annoyed with the car. Anyway she now has a new home, namely a hanger with loads of space. Parts to fit now are:- Aem water methanol .630 single jet , progressive controller, float switch, boost safe, going to fit into washer bottle 50/50 mix Six puch comp clutch stage 4 for six speed and lightweight fly Tt head gasket Arp head bolts New t61 turbo New rear discs and calipers in white Dot 5 fluid and new pads 25 row oil cooler Oil temp gauge and sensor fitting for sump I also have two trd bonnets to repair and paint in White, one cf one fiberglass just been repairing. I have three days off next week so going to lock myself in the garage and get most of it done!!! Need yo get the girl finished as I'm going to race her in the RAF speed challenge next year and obviously just get some use out of her. As I said she was purchased as a tinkering toy but I want some use out of her next year!! I think I found the culprit of the fueling issue, I found the silicone hose on the pump had split so maybe that was causing a pressure drop. Who knows Link to comment Share on other sites More sharing options...
