Fly Posted February 4, 2013 Share Posted February 4, 2013 (edited) Hi guys well thought I would start a progress thread though I was hampered this weekend with having to build my carport/garage extension. So this weekend has mainly concentrated on ripping out the dash and wrapping in 2/2 carbon fiber. The reason for this was tha my car had a airly boring facelift dash and secondly had Ben fitted with the factory fit wood effect which had left lots of sticky rubbery stuff. Here's the progress :- Should get the rest cut back this week and re fitted and with the added room of my carport I can start stripping the bumper and headlights off . Not a lot of progress but getting there! Edited January 29, 2014 by Fly (see edit history) Link to comment Share on other sites More sharing options...
FOSTA Posted February 4, 2013 Share Posted February 4, 2013 Good to see your getting a start mate. Link to comment Share on other sites More sharing options...
Fly Posted February 4, 2013 Author Share Posted February 4, 2013 Yea hardly ground breaking stuff but she will get there eventually!!! My powder coating aching came today too!!! Link to comment Share on other sites More sharing options...
d-_-b Posted February 4, 2013 Share Posted February 4, 2013 Dash is looking sweet mate! Great to see the thread up & started dude! Will get this added up to the Club NA-T section as well Link to comment Share on other sites More sharing options...
Fly Posted February 12, 2013 Author Share Posted February 12, 2013 So it's been a little slow as I have been waiting on parts etc. so the dash is about finished, not bad but the top section needs re skinning as you can see te folds in areas. I intend to install my boost and far gauge below the stereo where the lower din used to be And a few parts came today so fingers crossed I will attack the sump and get that tapped for the drain line Link to comment Share on other sites More sharing options...
Fly Posted February 12, 2013 Author Share Posted February 12, 2013 So parts list is T61 turbo , have k27 as a back up Manifold Down pipe 50mm waste gate Bov - should be ssqv bov so sending t back Screamer pipe Oil feed line - oil return kit on the way Walbro 255 fuel pump 440cc injectors and resistor box Intercooler and pipe work - was for a tt so needs modifying Greedy profec b boost controller 10 row oil cooler - still need a plumping/relocation kit and sandwich plate Polished intake pipe Boost gauge. Innovate wideband afr gauge and sensor Gaskets and fittings plus various other tiny bits Emangae ultimate....well we will see, I ordered this a week ago from someone breaking their car on piston heads and has of yet not arrived so I may be out of pocket here and searching for another. Will obviously grab more parts along the way Link to comment Share on other sites More sharing options...
buster Posted February 12, 2013 Share Posted February 12, 2013 Good work mate na-t is becoming quite common... Keep the updates coming in Link to comment Share on other sites More sharing options...
Fly Posted February 12, 2013 Author Share Posted February 12, 2013 Dude talk to me about the drain line, did you make your own or get one in a kit?? Link to comment Share on other sites More sharing options...
listy Posted February 12, 2013 Share Posted February 12, 2013 Is that innovate gauge wideband? Link to comment Share on other sites More sharing options...
Josh42 Posted February 12, 2013 Share Posted February 12, 2013 Info on drain line buster? Link to comment Share on other sites More sharing options...
buster Posted February 12, 2013 Share Posted February 12, 2013 I got one made up 10an fittings and made my own bottom flange Think if I remember I've got 1x oil line around 450mm long with a 45' bend on the female end (check your length yourself as I can't measure as my car is to far away) 1x male to male 45' bend 1x standard 10an turbo flange I bought a male to male joiner and cut one side off, made up a plate to fit over the hole on the sump and drilled 3 holes 2 for the bolts and one for oil line and got the joiner welded on Each manifold is different and getting the oil line to fit between the turbo outlet (hot side) and bend before the manifold is tricky but persistence is key Hope this helps bud Link to comment Share on other sites More sharing options...
Fly Posted February 12, 2013 Author Share Posted February 12, 2013 Is that innovate gauge wideband? Yes has a bosh wb O2 sensor and data logger Link to comment Share on other sites More sharing options...
pjavon Posted February 12, 2013 Share Posted February 12, 2013 Do these pic's help, the bottom fitting needs to be a 45degree one though as the bottom pic otherwise it can hit the steering rack bolt Link to comment Share on other sites More sharing options...
Fly Posted February 12, 2013 Author Share Posted February 12, 2013 Thanks dude a picture paints a thousand words!!! I am free tomorrow so am going to sift through all my fixtures and fittings. Link to comment Share on other sites More sharing options...
Pulley Posted February 12, 2013 Share Posted February 12, 2013 Great choice in afr gauge, the innovate range is top quality Link to comment Share on other sites More sharing options...
Fly Posted February 12, 2013 Author Share Posted February 12, 2013 Great choice in afr gauge, the innovate range is top quality Yea read some great reviews on it seems that it is truly wideband and the data logging software looks great. Once I get underway I intend to replace the stock O2 sensors with the wb and bridge the ecu pins to read from the one gauge Link to comment Share on other sites More sharing options...
Fly Posted February 12, 2013 Author Share Posted February 12, 2013 P.s I won't lie, seeing all my parts stack up I'm getting excited and fingers crossed she will be ready in a few months for the good weather and jap fest, then I can join the ranks of the supra six speed singles !!! Link to comment Share on other sites More sharing options...
Fly Posted February 16, 2013 Author Share Posted February 16, 2013 Small update to the build, yesterday between chasing the dog around the garden having stolen my tools and the misses dragging me to look at antique stuff I manage to remove the air box and intake, undertray, front bumper, lights, fan shroud and got her jacked up ready to get the sump out. This also arrived today :- However, this may have been a miscommunication from my end but e harnesses/extension lead for the map sensor to emu was not included so I must now source one of these, is this just a lead that I can knock up with connectors from maplins or does it have to be an actual greddy one? Either way I though 300 for the lot wasn't a bad buy. Hopefully I should be ale to get the sump off, drilled and refitted today. Link to comment Share on other sites More sharing options...
Fly Posted February 24, 2013 Author Share Posted February 24, 2013 Only had a half day today. Refitted engine mounts Fitted oil return line. Fitted oil feed and union bolt. Fitted sandwich plate, new oil filter oil lines and oil cooler. Fitted manifold and wastegate. Link to comment Share on other sites More sharing options...
FOSTA Posted February 24, 2013 Share Posted February 24, 2013 Nice one dude Link to comment Share on other sites More sharing options...
Fly Posted February 24, 2013 Author Share Posted February 24, 2013 Dude, what intercooler pipe work did you use? Did you weld or just use different lengths and angles? Thanks again Link to comment Share on other sites More sharing options...
FOSTA Posted February 24, 2013 Share Posted February 24, 2013 Nah I just used silicone joiners, all 63mm strights and 90degrees Link to comment Share on other sites More sharing options...
d-_-b Posted February 25, 2013 Share Posted February 25, 2013 Off to a great start dude Well done for updates with pics too! - will gwet your thread added to our builds threads in the club section Link to comment Share on other sites More sharing options...
Fly Posted February 25, 2013 Author Share Posted February 25, 2013 thanks guys, the pics arent the best i promise i will get some better ones up soon. need to order some alloy piping/ more joiners and t clamps. Link to comment Share on other sites More sharing options...
Fly Posted March 3, 2013 Author Share Posted March 3, 2013 So today was spent mounting up the turbo which meant stripping down the turbo to mount the exhaust hosing to the manifold, typical xs power kit, I couldn't get the bolt in next to the exhaust turbine outer so had to grab a short m10 bolt. Still waiting on my dizzy cap and intercooler mounts, I'm hoping I should be done in three weeks. I gave up on Saturday as I was getting annoyed with my lack of progress, yes it does not make sense but if you've had enough then it's just not worth doing anything. My one piece of advice at the minute is if you do it's then, 1 buy a separate engine to work on, 2 have a big garage . Link to comment Share on other sites More sharing options...
