shetlandsupra Posted February 1, 2013 Share Posted February 1, 2013 can i run my bpu on normal unleaded 95 ron and can standard ecu be mapped? running 400bhp live in shetland isles where there is no other fuel! cheers Quote Link to comment Share on other sites More sharing options...
adam1983 Posted February 1, 2013 Share Posted February 1, 2013 Is it jspec or uk? Stock ecus can't be mapped as far as I am aware Quote Link to comment Share on other sites More sharing options...
safcdixon Posted February 1, 2013 Share Posted February 1, 2013 I dont think its recomended on bpu as in cold weather the engine can run lean, it may be easier to buy some octane booster instead Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 1, 2013 Share Posted February 1, 2013 No, standard ECU can't be mapped. A 400bhp BPU car on 95 ron will explode very soon. Welcome to the club, by the way. Quote Link to comment Share on other sites More sharing options...
mellonman Posted February 1, 2013 Share Posted February 1, 2013 SAFELY No and No and welcome The stock jspec is mapped to 100 ron petrol, you can empty the tank and put in 95 and the disconnect the battery and reset all the fuel trims but has no affect o timing which my be off for 95 ron Quote Link to comment Share on other sites More sharing options...
Ian Ian Posted February 1, 2013 Share Posted February 1, 2013 Good Afternoon chap thats a long way north Is your Supra UK or an import ? if its an import its will have been set up in Japan to run on 97+ ron petrol or whatever they have in Japan, but if 95 ron is all you have its kinda hobsons choice you have there ....also the Standard ECU isnt mappable as far as i know Cheers -Ian- Quote Link to comment Share on other sites More sharing options...
drift_bear Posted February 1, 2013 Share Posted February 1, 2013 As the op said, there's no other option up in Shetland for anything over 95ron His car is the wide body tamon supra that used to be on here... Quote Link to comment Share on other sites More sharing options...
Abz Posted February 1, 2013 Share Posted February 1, 2013 The short answer is yes to you can run it on normal unleaded (off boost), how long that lasts I don't know. No the standard ECU can not be mapped. I have ran normal unleaded when I had no choice but ran the car off boost, didn't feel great, lumpy idle & miss fired when I tried a hard pull. If you are running 400bph I'd try & either get a mappable ECU or just run off boost or buy an NA! Quote Link to comment Share on other sites More sharing options...
shetlandsupra Posted February 1, 2013 Author Share Posted February 1, 2013 so best option is to get a new ecu and get it mapped? - - - Updated - - - thanks for all your posts! Quote Link to comment Share on other sites More sharing options...
Abz Posted February 1, 2013 Share Posted February 1, 2013 so best option is to get a new ecu and get it mapped? - - - Updated - - - thanks for all your posts! Do you have a UK Spec or JSpec Supra? A good point was made above if it is a UK Spec you can run 95 Ron, though I personally would be cautious of putting in 95 Ron if you are running full BPU. Do you have an AFR gauge in the car? Quote Link to comment Share on other sites More sharing options...
shetlandsupra Posted February 1, 2013 Author Share Posted February 1, 2013 jspec supra not got afr yet i was thinkin just to buy a mapable ecu any ones you'd suggest that arent just to pricey? Quote Link to comment Share on other sites More sharing options...
Havard Posted February 1, 2013 Share Posted February 1, 2013 (edited) The short answer is yes to you can run it on normal unleaded (off boost), how long that lasts I don't know. No the standard ECU can not be mapped. I have ran normal unleaded when I had no choice but ran the car off boost, didn't feel great, lumpy idle & miss fired when I tried a hard pull. If you are running 400bph I'd try & either get a mappable ECU or just run off boost or buy an NA! This is what I believed. You cannot doi the car any harm running it on 95 Ron unleaded. I have done this a couple of times on long runs and not been able to get a higher Ron rating. As far as I know (off boost) this will not be an issue. On boost is a different matter and the car will run lean if too much is asked of it. I ran my NA on 95 Ron and LPG for three and a half years and 17K miles. This car has now done another 50k miles on LPG alone. I laugh at al the scare mongering about the car car blowing up if you don't empty your ash trays etc. If I were you up there I would run it on 95 and don't go mad or just buy an NA. Octane booster is also an option but I think it's a bit hit and miss getting a good mixture. H. Edited February 1, 2013 by Havard (see edit history) Quote Link to comment Share on other sites More sharing options...
Thorin Posted February 1, 2013 Share Posted February 1, 2013 Yes (but personally I'd stick to SUL), and no. Quote Link to comment Share on other sites More sharing options...
bignum Posted February 2, 2013 Share Posted February 2, 2013 A "proper" water injection system should help if not solve your problem, i wouldn`t just fit 1 and hope for the best though, get someone with a set of det cans to have a listen to it ideally before and after the w/i system. Quote Link to comment Share on other sites More sharing options...
