2jz.jjk Posted February 1, 2013 Share Posted February 1, 2013 (edited) Hey all, Need help onto this step. I have removed the Top bolt for Transmission Fold already, just thats it stuck and i want to confirm this is the transmission mount and if i need to take off anything else and how far do i let it drop with a jack supporting it? Edited May 17, 2013 by 2jz.jjk (see edit history) Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted February 1, 2013 Share Posted February 1, 2013 If your dropping the gearbox, leave the 4 middle bolts you've circled and remove the 4 on the outboard edge of the alloy crossmember. Quote Link to comment Share on other sites More sharing options...
2jz.jjk Posted February 1, 2013 Author Share Posted February 1, 2013 (edited) Yes that makes sense, Would i need to worry bout the tailshaft and also where do i need to place the jack and how much should i need to drop it. thanks Edited February 19, 2013 by 2jz.jjk (see edit history) Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted February 1, 2013 Share Posted February 1, 2013 Take the prop shaft out, put the jack, with a block of wood on, around the middle of the box, lower down until you can get the bolt out. Quote Link to comment Share on other sites More sharing options...
2jz.jjk Posted February 1, 2013 Author Share Posted February 1, 2013 (edited) all sorted. Edited May 17, 2013 by 2jz.jjk (see edit history) Quote Link to comment Share on other sites More sharing options...
