RobD Posted January 31, 2013 Share Posted January 31, 2013 As above, am I right in thinking that I shouldnt need a speedo converter if I'm using a UK spec ECU, loom and UK spec Speedo? Rob Quote Link to comment Share on other sites More sharing options...
JasonR24 Posted February 1, 2013 Share Posted February 1, 2013 the uks are de limited too arent they? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted February 1, 2013 Share Posted February 1, 2013 Are you changine the loom behind the dash? I think thats where the convertor gets tapped innto the loom so if you replace that part too it should remove the limiter and convert the dash clocks to mph Quote Link to comment Share on other sites More sharing options...
JasonR24 Posted February 1, 2013 Share Posted February 1, 2013 Are you changine the loom behind the dash? I think thats where the convertor gets tapped innto the loom so if you replace that part too it should remove the limiter and convert the dash clocks to mph ill have to rip this out the shell then! want it reading correctly Quote Link to comment Share on other sites More sharing options...
safcdixon Posted February 1, 2013 Share Posted February 1, 2013 ill have to rip this out the shell then! want it reading correctly Im not certain thats the correct tbh Jason but i think thats the case it should be anyway Quote Link to comment Share on other sites More sharing options...
RobD Posted February 1, 2013 Author Share Posted February 1, 2013 (edited) ill have to rip this out the shell then! want it reading correctly Then you'll have to buy a UK dash and loose the facelift dash! Ill just buy a converter and tap it in it'll be easier Edited February 1, 2013 by RobD (see edit history) Quote Link to comment Share on other sites More sharing options...
