Re-fitting ABS speed sensor, what grease?
Scott
I'm fitting some refurbished wishbones etc and I'm looking to re-fit the ABS sensor. I'm fairly certain the one I took out, before it crumbled to bits, had a lot of gooey white grease stuff all over it. Should I be replacing this grease when fitting the "new" one? If so, what sort of grease should I be using?
Thanks
