Lowering Springs-Current
TuneR
Okay so i want a set of lowering springs as i like the comfort of the standard car. I dont want anything mad bar slightly stiffer and lower front than rear due to the current nose up stance. The car has OEM Tokico's*, 18's on it and only a WW front lip. I've done a bit of research and from what i can see the Eibachs were the best one. I wanted to see what else was out there so after a search i've yielded the following:
Make: F/R lowering
Tein: 36/42mm i dont want further lowering of the car on the rear.
H&R: -1.1/1.0" not enough in the front imo
Gmax: -40/40mm i dont want an equal drop
Tanabe: -1.2/1.0"
Eibach: -1.2/1.0" (only place i seem to be able to find them is Suprastore)
So only the Tanabe and Eibach seem to be the only suitable ones. Is the general concensus still for Eibach? Also is there any place somewhere in Europe that i can get them or does it have to be the US?
Cheers
The Eibachs spring rates are the nearest to o/e
You could try Ibrar at Speedwells, he got me mine
a few years ago so might still be able to source them
for you
http://www.fensport.co.uk £288 inc vat in stock
There listed on Demon Tweeks
http://www.mkivsupra.net/vbb/showthread.php?267488-Coilover-Spring-Rate-Register&highlight=spring+rates
