Hank_Swe Posted January 29, 2013 Share Posted January 29, 2013 I've just bought a trd wing for my Supra mkiv. What is the proper installation sequence when fitting it to the car? Should i install the side pieces on the car to start with, and then fit the wing blade? Or is the proper way to screw the wing togehter before fitting it to the car? Link to comment Share on other sites More sharing options...
Fitz Posted January 29, 2013 Share Posted January 29, 2013 I would assume you screw the sides to the blade first then mount it to the car. As if you tried to install the sides on the car first you'd have no leeway for the blade to fit. Link to comment Share on other sites More sharing options...
wile e coyote Posted January 29, 2013 Share Posted January 29, 2013 Loose fit blade to sides then attach sides to car and tighten blade, making sure you got blade the right way up lol Link to comment Share on other sites More sharing options...
drift_bear Posted January 29, 2013 Share Posted January 29, 2013 Loose fit blade to sides then attach sides to car and tighten blade, making sure you got blade the right way up lol Link to comment Share on other sites More sharing options...
Dnk Posted January 29, 2013 Share Posted January 29, 2013 Just too be awkward Fit the sides first to the boot lid but leave them slightly loose then fit the blade, then tighten the sides then tighten the blade. Link to comment Share on other sites More sharing options...
safcdixon Posted January 29, 2013 Share Posted January 29, 2013 Just too be awkward Fit the sides first to the boot lid but leave them slightly loose then fit the blade, then tighten the sides then tighten the blade. This is the way ive done it countless times works a charm and nowhere near as awkward to handle imo Link to comment Share on other sites More sharing options...
Dnk Posted January 29, 2013 Share Posted January 29, 2013 This is the way ive done it countless times works a charm and nowhere near as awkward to handle imo Agreed, its the way i've always done it Link to comment Share on other sites More sharing options...
