water methanol pump specs for bpu
costas1
i already have a kit intalled on the car..it is the ERL water methanol kit 1S ...but it is old and out of production for years now and cause my pump is dead i want to replace just the pump and i am looking something similar..i was thinking for an AEM but do not know if it is ok..i mean the specs
AEM Kit will do the trick!
Part # AEM 30-3000
The Water Injection Kit is an economical, complete install kit with no extra parts needed, user-friendly setup solution for reducing air inlet temps and increase charge density in boosted vehicles. Allows the user to safely run higher boost pressures and suppress detonation allowing the utilization of more timing and boost. Performance will no longer be compromised when running lower octane fuels. Features a high-pressure pump with progressive controls, a 1 gallon tank with integral fluid level sensor, interchangeable nozzles for easy flow adjustment and an integrated system status dash light with easily identifiable error codes including short circuits, battery voltage problems and low fluid warning.
Key Features:
•Complete kit, everything is included
•Progressive controller driven 150 PSI pump
•1 gallon tank with integral fluid level sensor
•Dash light for system status and low fluid warning
•Alcohol Compatible (up to 50% in solution with water)
•Progressive controller, provides boost dependent variable flow
•Provides output to either decrease timing or boost if the system runs out of fluid or detects an error
•Kit includes three jets to match your power requirements
http://www.mvpmotorsports.com/Templates/frmTemplateM7.asp?SubFolderID=204&SearchYN=N
