knocking and warning light
ksbkrew
Hi!
i'm worrying about knocking with my car ( a uk single with 850cc)
I'm boosting at 1.4bar-1.5bars with a XS T70 and running at 11.0 AFR (with a mapecu1 so cannot play with the advance/retard of timing)
I'm never get a CEL flashing while rolling and boosting up to the max of RPM so i think that the OEM knock sensor doesn't hear a problem.
But my question is : can we trust the OEM Sensor??
i have seen that some knock light are available (like gizzmo or turboXS), are they more reliable than the oem? is there any interest of buying one? or my OEM one will do correctly his job and warns me when there 's a real problem??
Many thanks
the stock timing is for 2 small trubo's in sequencial not one that comes online at 4,000rpm that flows twice as much air, i expect you will be deting all over the place top end low down you will be loosing power by running rich with timing pulled for the first turbo or where it would be ,
i have a T67 with a piggy back ecu that has 10 deg timing pulled up top for my map at 1.3 bar
even when i had hybrids this had 5 deg timing pulled to stop det, adjustable cam pulleys might help but not solve the ignition timing thats the issue
the supra's that you see runing with a mapecu1 could well be a 1jz that have a map for single turbo, the map2ecu would be alot better choice IMHO
Interesting, I'm running an EMU and I pull all of 0 degrees of timing throughout my 1.3bar load sites, and even 1.4bar, my maximum. I also advance up to 15deg below 4000rpm off/low boost as well. No det at all, as verified by det cans and years of running it like this. Perhaps you have an underlying issue like a hot spot in the cylinder head?
T61's I used to have to remove a couple of degrees of timing around the sequential transition point, but that was it. I've never had to remove anything like ten degrees.
Edit - do you have a MINES ECU or something that might already have a more aggressive timing map?
this is intresting i have a stock jspec ecu with the fic 8 to be fair it did have a firm ware issue that may have caused this issue but it made good power as it is 524bhp / 510ftlb @ 1.3 bar
T67 0.68 dbb
i can only guess that the timing must be advanced at the crank then or hot spot as you say, even when i searched on supra forums they have 7 deg pulled with most of there maps but have poor gas
and the result is: det damages on cylinder 1-2-3-4-6. The only which is without damages is the 5.
i'm disgusted...
Unfortunately the cause of that...
Is pretty obvious :shrug:
T67 0.68 dbb
I can only guess that the timing must be advanced at the crank then or hot spot as you say, even when i searched on supra forums they have 7 deg pulled with most of there maps but have poor gas
I've got a T67 dbb with a 0.68 housing as well :) At 1.4bar it dyno'd 570bhp @SRR, and that was with 4deg timing backed off due to my paranoia, so it'll be a tad more than that now as that timing is back in. Going up to 1.4 and putting your 10deg timing back in would prob lift you up to the same output, so your timing must be actually retarded rather than it being some red herring reading. Hmm.
i'm disgusted...
feel sorry for you mate but it was to be expected with no real mapping with det cans or a ecu that can retard timing ,
get a decent ecu mate pay there and save on not having to rebuild again
Hay stop calling my car retarded :p
to be fair i had a look at my map last night its 8deg at 1.3 and 10deg at 1.4 hard to tell fully as its in psia (absolute so changes slighty depending where you are to sea level), but it goes well and is safe so im happy.
