No power after jump starting
Guest Deano hks
Guest Deano hks
Hi, tried to jump start my supra earlier and the engine started to turn over but then it made a noise like a fuse blowing. Now I have no power to my car at all, I checked the fuses and they seem to be fine. was wondering if it sounds like the 120a fuse has gone or any other ideas????
Guest Deano hks
Iirc The ecu has too relearn and reset, take it for a little drive and see if it improves.
I have no power to turn the engine over mate , no ignition, lights , etc
Isn't the 120 amp fuse bolted into the fuse box so you can't just pull it out ?
Should be pretty obvious if its blown as its wasted away on the top so this
is where it melts and you can see this as it has a clear top.
You didn't get the jump leads on backwards did you as this will blow the
120 amp fuse ?
Guest Deano hks
I had a quick look today and tested the fuses in both fuse boxes and they all seem fine. I'm now thinking maybe it has something to do with the immobiliser.........and no I didn't get the jump cables mixed up. I need to have a good look round it when I get a day off.
