HKS exhaust fitting
Jellybean
Anybody any tips for fitting?
I presume it makes life easier to bolt the system together first as opposed to fitting the two sections individually?
Recommended to replace the exhaust hangers? As far as I know it uses the OEM hangers, if I need any ,will you get them at a motor factors or better going via Toyota
Thanks
I fitted mine same as any others should be 2 nut & bolts 1 gasket from cat back on back box 4 nuts & bolts 1 gasket and hangers should be on welded to exhaust and match car mountings rubber mountings are easy to get and some uni fit ones are fatter and last longer
you should have no probs mate my super dragger fitted better then the standered one!! and sat better hight in the bumper
