Can my head be repaired?
Swampy442
After meeting you in person id say your head is totally unrepairable lol.
Ho ho! ;) Its a 2JZ head mate.
Digsy, you make a good point, I didnt check to see if it was pick up on the cam itself or a groove, but I will check. The cap is also damaged in a similar way.
Gareth, I thought that might be the case.
Cam bearings dont have a particularly hard life compared to crank and big end bearings. All the load comes from the springs and so acts in one direction. Although they are direct fed they can run on feck all oil. In fact te size of the oil hole is usually goverened by the smallest drill that the production line can guarantee won't keep breaking (usually about 3mm).
You are liable to do more damage by trying to repair it or get it rebored. Provided it (and the camshaft) cleans up ok with a light rub of fine emery you might be OK.
