Torque converter lock up help.
Kaan W
So I thought I would start this thread in relation to my strange dyno result thread as this is the main topic of why my reading was all over the place. Basically my torque converter is not locking up giving me a sluggish top end and a high fuel consumption on motorways. Is 4000rpm normal at 70mph? :think:
So the information I have so far is that the lock up switch is activated by pin 14b in the O.E ECU. I understand I need to test continuety between this pin and the gearbox connection and also output voltage from pin 14b.
So the questions I have, as I have no electrical knowledge what so ever are -
1) Do I measure resistance from pin 14b with a multimeter with the car at WOT in 3rd, at idle or with the battery disconnected?
2) How do I measure the resistance do I splice into the wire or pull it out completely and plug the multimeter in?
3) Am I right in thinking that lock up should only occur in 3rd & 4th?
EDIT: Just found this -
LOCK-UP OPERATION
When the engine control module decides, based on each signal, that the lock-up condition has been met, the current through
EFI NO. 1 fuse flows from the EFI main relay to TERMINAL 3 of the electronically controlled transmission solenoid to
TERMINAL 7 to TERMINAL (B) 14 of the engine control module to GROUND, so continuity to No. 3 (for lock-up) causes
lock-up.
Thanks
Edited by Kaan W (see edit history)
Get a wire that you know is complete
attach to one end of 14b wire
put one test probe on one end of your wire and one on the other end of 14b
Basically create yourself a loop of wire so you can test at one point ( ill get a pic )
Yeah a pic would help alot, thanks!
no the continuity of the wire, it should have no resistance. then you know there is no breaks in the wire.
To measure the voltage you will need to get it all plugged back up, and tap in to the wire and see if it registers a voltage while driving it.
Oh I see, so basically put the red and black probes on either end of the wire I think may be broken and if theres resistance then its broke?
But to test pin 14b it will be voltage and I would have to earth the multi meter then put the red probe onto the pin and read the voltage when the torque converter should be locking up?
yes and you use another piece of wire to act as a lead extension
this is correct, do you know what voltage you are looking for ? im guessing somewhere between 5-12v
I dont have a clue tbh and ive been looking at manuals all day but still havent gathered any usefull information that I need. I could probably fix it myself if I new what to do.
Everyone's advice above applies - it's all good. One hour of technician time at most - maybe bite the bullet?
Its not about biting the bullet mate ive had cash waiting to pay soneone to fix this asap. I dont think anyone knows to be honest so im gunno have to rip everything apart and figure for my self!
Small question, what box is in your car? your first post has gte wirring numbers then the edit has the ge discription.
if gte the ecu takes ign based power from the solenoid to ground. if ge the ecu outputs power to the solenoid.
Its a GTE.
