buster Posted January 23, 2013 Share Posted January 23, 2013 My drivers side window works sometimes and sometimes slow then stops and some time not at all. It's only started tonight I moved the car out of my yard went to put the window up and nothing happened. Everything moves as it should ie, glass is in its guides. I'm thinking it might be the switch but unsure, has anyone elce had this if so what did you do to sort problem? Thanks. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 23, 2013 Share Posted January 23, 2013 Mine just goes straight up or stright down and cant stop it halfway, pretty anoying.... Quote Link to comment Share on other sites More sharing options...
keron Posted January 23, 2013 Share Posted January 23, 2013 Sounds like it could be the window mech.... Most common thing on these currently... We sell loads! Take the door card off and inspect the cable and guide that runs in the mech... Usually frays And gets jammed etc... Can snap and window can drop, break and you'll have to prop it up... If it is this we have new and used in stock... Quote Link to comment Share on other sites More sharing options...
buster Posted January 23, 2013 Author Share Posted January 23, 2013 Cable looked fine did look at that real strange will try and get a clip of it and post up on the weekend Quote Link to comment Share on other sites More sharing options...
