Kaan W Posted January 23, 2013 Author Share Posted January 23, 2013 When in manu mode and in D it will feel sluggish pulling away from a standing start. If manu isnt working it will pull away in 1st then change to 2nd and then 3rd. When ever I pull away in D it always goes from 1st to 2nd etc. I forgot to mention my "D" light in the speedo does not work now when before im pretty sure it did. Could this be an answer to something? Quote Link to comment Share on other sites More sharing options...
Wez Posted January 23, 2013 Share Posted January 23, 2013 You have gained approx 100ft/lbs Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 23, 2013 Author Share Posted January 23, 2013 You have gained approx 100ft/lbs Which should in theory be 699bhp @6800rpm right? Quote Link to comment Share on other sites More sharing options...
chazuk Posted January 23, 2013 Share Posted January 23, 2013 Which should in theory be 699bhp @6800rpm right? lol do what everyone else does mate add another 20% on it and call it hub hp it makes people feel happy Quote Link to comment Share on other sites More sharing options...
Wez Posted January 23, 2013 Share Posted January 23, 2013 Which should in theory be 699bhp @6800rpm right? What equation did you use to get that? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 23, 2013 Author Share Posted January 23, 2013 The same equation hp is calculated in the first place. Torque x rpm / 5252 = hp Quote Link to comment Share on other sites More sharing options...
chazuk Posted January 23, 2013 Share Posted January 23, 2013 The same equation hp is calculated in the first place. Torque x rpm / 5252 = hp are those dyno graphs caluated flywheel hp from ssr as Ryan gave me 2 print outs one was rear wheel hp and the other the added on 20% caluated flywheel hp ? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 23, 2013 Author Share Posted January 23, 2013 are those dyno graphs caluated flywheel hp from ssr as Ryan gave me 2 print outs one was rear wheel hp and the other the added on 20% caluated flywheel hp ? It was at surrey rolling road yeah but I assume its flywheel hp Quote Link to comment Share on other sites More sharing options...
chazuk Posted January 23, 2013 Share Posted January 23, 2013 It was at surrey rolling road yeah but I assume its flywheel hp Fair enough did you get a graph showing boost and afr? there will be loads more in it for sure mate down to the autobox problem on the dyno as if that is flywheel at 1.8 bar your wheel hp will be 432hp which is low for your setup Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 23, 2013 Author Share Posted January 23, 2013 Fair enough did you get a graph showing boost and afr? there will be loads more in it for sure mate down to the autobox problem on the dyno as if that is flywheel at 1.8 bar your wheel hp will be 432hp which is low for your setup Oh it could be at the hubs then, i'll have to ask him. No I didnt get any of that Quote Link to comment Share on other sites More sharing options...
Wez Posted January 23, 2013 Share Posted January 23, 2013 For autos dont they just provide wheel HP? Quote Link to comment Share on other sites More sharing options...
Luxluc Posted January 23, 2013 Share Posted January 23, 2013 That's a fast spooling setup. Great torque graph. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 23, 2013 Author Share Posted January 23, 2013 (edited) That's a fast spooling setup. Great torque graph. It does feel very aggresive to drive but the numbers are just not showing. Also I just took the car out and overdrive and manual mode is working correctly after reading what the actuall functions of these are Im really baffled on the whole situation and dont know what to do Edited January 23, 2013 by Kaan W (see edit history) Quote Link to comment Share on other sites More sharing options...
DaveR Posted January 23, 2013 Share Posted January 23, 2013 *Cough* Buy a manual box... *Cough* Sorry it didn't work out for you matey. Hope it resolves. You know how it is with these things - you can guarantee it'll turn out to be something simple and be an easy fix. I think these little niggles are to be expected when carrying the level of modifications you are. Same reason my car was on the rollers just before yours! Quote Link to comment Share on other sites More sharing options...
Luxluc Posted January 23, 2013 Share Posted January 23, 2013 Having a look at the 1.6 graph shows a prefect street setup. The 1.8 curve is a little bit strange... If it punches slightly more on high boost, it's as it should be. Enjoy it Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 23, 2013 Author Share Posted January 23, 2013 *Cough* Buy a manual box... *Cough* Sorry it didn't work out for you matey. Hope it resolves. You know how it is with these things - you can guarantee it'll turn out to be something simple and be an easy fix. I think these little niggles are to be expected when carrying the level of modifications you are. Same reason my car was on the rollers just before yours! Been thinking about going manual after all this mate lol. It probably is something simple but it just seems there is always something, I definately need to consider a rebuild at some point. How did yours get on anyway? Having a look at the 1.6 graph shows a prefect street setup. The 1.8 curve is a little bit strange... If it punches slightly more on high boost, it's as it should be. Enjoy it It is strange I just cant get my head around it. Its hard to tell if theres a difference but it definately dont feel slower, its something I will have to wait until the summer when the roads are hot. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 23, 2013 Share Posted January 23, 2013 (edited) Im running 558bhp on my single and i cant say mine launches as hard as yours does mate! when you floor it, it seems to knock down and then it launches so quick... i was well impressed. I wouldnt worry mate, would have been nice to get that "print out" but who cares, if anyone challenges you, then race them and show them up!!! Not much will beat this on the street and a single 6 speed will struggle to launch off like this! proper weapon Edited January 23, 2013 by Rob_Mitchell (see edit history) Quote Link to comment Share on other sites More sharing options...
Luxluc Posted January 23, 2013 Share Posted January 23, 2013 if anyone challenges you, then race them and show them up!!! a single 6 speed will struggle to launch off like this! To be confirmed Quote Link to comment Share on other sites More sharing options...
Sheefa Posted January 23, 2013 Share Posted January 23, 2013 Definitely get WHP reading mate, flywheel is a totally pointless guesstimate. Get the RWHP and quote that as your figure, none of this adding between 10-25% cack. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 23, 2013 Share Posted January 23, 2013 To be confirmed Against a single 6 speed with similar power! not something like yours Quote Link to comment Share on other sites More sharing options...
DaveR Posted January 23, 2013 Share Posted January 23, 2013 Been thinking about going manual after all this mate lol. It probably is something simple but it just seems there is always something, I definately need to consider a rebuild at some point. How did yours get on anyway? Very well, I'm pleased to report! See here. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 23, 2013 Author Share Posted January 23, 2013 Im running 558bhp on my single and i cant say mine launches as hard as yours does mate! when you floor it, it seems to knock down and then it launches so quick... i was well impressed. I wouldnt worry mate, would have been nice to get that "print out" but who cares, if anyone challenges you, then race them and show them up!!! Not much will beat this on the street and a single 6 speed will struggle to launch off like this! proper weapon I cant really say much because its the only supra ive ever been lol. It does drive real nice but I have to say when it was dyno'd at that figure it makes you wonder what all these 1000+ lads experience on the street Im sure you know your stuff mate so I trust you that it must be quick, but as you said a nice printout would have just finished the day nicely. I think I might just attend some rwyb days to get a better knowledge of the setup and see if its doing what its suppose to To be confirmed Ha I doubt it mate yours will be stupidly fast Definitely get WHP reading mate, flywheel is a totally pointless guesstimate. Get the RWHP and quote that as your figure, none of this adding between 10-25% cack. I guess i'll have too, wheres the closest hub dyno to Kent do you know mate? Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted January 23, 2013 Share Posted January 23, 2013 TDI have a hub dyno,they are at Lakeside shopping centre Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 23, 2013 Author Share Posted January 23, 2013 TDI have a hub dyno,they are at Lakeside shopping centre Ah ok I didnt know that, thats closer to me too i'll have to take a trip up there when I get time. Quote Link to comment Share on other sites More sharing options...
nero Posted January 23, 2013 Share Posted January 23, 2013 If there is a lockup issue then that can start in the electronics, the auto boxes are all the same for JDM or USDM. The transmission although beefed up should not loose any power, if anything it will gain power. Its a stronger unit and will put the power to the ground vs slipping like the stock unit will. Quote Link to comment Share on other sites More sharing options...
