Guest 2jzville Posted January 21, 2013 Share Posted January 21, 2013 First post on these forums so hope get this all correct.... I have a 96 J-Spec Supra and it has as stock a four spoke airbag steering wheel, I am looking to get rid of this grandad Camry spec wheel in favor of an Original Kouki 98-02 airbag equipped 3 spoke steering wheel. What I am trying to work out is will this fit straight on with no need for major mods to get it to fit? Does the later model wheel have the same sprocket fitment as the 96 car? Also how hard is it to remove the factory 4 spoke wheel and airbag? Any input or help on this one would be greatly appreciated. Thanks Phil Link to comment Share on other sites More sharing options...
mihai Posted January 21, 2013 Share Posted January 21, 2013 Is 4 am in the morning in Europe is nowbody on forum now... i Link to comment Share on other sites More sharing options...
Tyson Posted January 21, 2013 Share Posted January 21, 2013 First post on these forums so hope get this all correct.... I have a 96 J-Spec Supra and it has as stock a four spoke airbag steering wheel, I am looking to get rid of this grandad Camry spec wheel in favor of an Original Kouki 98-02 airbag equipped 3 spoke steering wheel. What I am trying to work out is will this fit straight on with no need for major mods to get it to fit? Does the later model wheel have the same sprocket fitment as the 96 car? Also how hard is it to remove the factory 4 spoke wheel and airbag? Any input or help on this one would be greatly appreciated. Thanks Phil Don't know about the new wheel but the old one is easy to remove just make sure you disconnect the battery so it doesn't blow up in your face Link to comment Share on other sites More sharing options...
Guest 2jzville Posted January 21, 2013 Share Posted January 21, 2013 Easy to remove is great (Battery will be disconnected so I can save face), is it just a screw on each side of the wheel under the plastic tabs to get the airbag off and then the standard big nut behind the airbag to get the wheel off. The big thing I am trying to confirm, is are the sprocket fitments the same on a 96 as on a 98-02? Is there one type of boss kit to fit all years of Supra or do they change with the face lift model and as the years go on? Link to comment Share on other sites More sharing options...
listy Posted January 21, 2013 Share Posted January 21, 2013 As far as I know, it's the same mate. Link to comment Share on other sites More sharing options...
Nic Posted January 21, 2013 Share Posted January 21, 2013 Yes straight swap, although you may need a adapter harness for the airbag. Most if not all Toyota and Lexus steering wheels are interchangeable, I've recently fitted a 2012 Yaris steering wheel on the MR2. Link to comment Share on other sites More sharing options...
