James Millers SRD PT6262 8 Speed Build
Lee P
  • Replies 315
Looks awesome :cool:
What diff are you using? And any idea what the theoretical top speed is with the gearing? This could potentially be a bit of a game changer - much quicker through the gears than a 6 speed or tiptronic, and better motorway fuel economy.
We chose to put a 6 speed diff in this as its closer to the ISF ratio
The ISF ratio is 2.94
Auto diff is 3.769
6 speed is 3.266
The ISF owners talk about changing to a 3.266 as they feel that the higher gears are just for cruising so that ratio should suit pretty well.
Will give great acceleration but as you say cruising on the motor way will be good fuel economy as rpm will be low.
I have a chart of the speed per gear on the ISF, will post it in a sec
It is win win for everyone I think.
From what I've read, the AA80E box can change gears pretty quickly. 0.1s on upshift and 0.3 downshift, that was on the Lexus ECU. I suspect the Syvecs can speed that up.
Pretty epic really.
why does is over rev when changing is the lower gears ?
I take it thats because you still have your foot on the throttle and as the gear changes Ie clutch engaged the revs rise as would in a manual car if changing gears with out moving the throttle ?
I assume thats down to it not been mapped fully yet?
Just worked out the gearing - and made the following assumptions.
Final Drive: TT JSpec 6spd Facelift
Tyre Width: 275
Aspect Ratio: 35
Rim Size: 18
Speeds at 7000rpm are:
1st: 36.5
2nd: 61.6
3rd: 90.0
4th: 114.5
5th: 136.2
6th: 167.7
7th: 203.5
8th: 244.8
80mph would be:
3rd: 6500rpm
4th: 5000rpm
5th: 4250rpm
6th: 3400rpm
7th: 2850rpm
8th: 2350rpm
Not too bad at all.
Moving to a Auto Diff:
1st: 30.7
2nd: 51.9
3rd: 75.8
4th: 96.5
5th: 114.8
6th: 141.3
7th: 171.4
8th: 206.2
80mph: would be:
4th: 5700rpm
5th: 4900rpm
6th: 4000rpm
7th: 3300rpm
8th: 2700rpm
I think the Auto Diff would suit it best.
Will it have an auto mode as well? I could see myself getting a little bit irritated having to constantly change gears (being 8 speed).
Yes of course full auto mode :)
Manual mode and a sport mode.
As said this is just purely a base calibration just to get the car driving but think it's more the Rev counter.
Edited by Lee P (see edit history)
Tyre Width: 275
Aspect Ratio: 35
Rim Size: 18
1st: 36.5
2nd: 61.6
3rd: 90.0
4th: 114.5
5th: 136.2
6th: 167.7
7th: 203.5
8th: 244.8
80mph would be:
3rd: 6500rpm
4th: 5000rpm
5th: 4250rpm
6th: 3400rpm
7th: 2850rpm
8th: 2350rpm
Not too bad at all.
1st: 30.7
2nd: 51.9
3rd: 75.8
4th: 96.5
5th: 114.8
6th: 141.3
7th: 171.4
8th: 206.2
80mph: would be:
4th: 5700rpm
5th: 4900rpm
6th: 4000rpm
7th: 3300rpm
8th: 2700rpm
We drove it with the auto diff and first gear especially felt very short
Feels much better on the 6 speed diff
Will see how it is when mapped and may try an auto diff as well
