James Millers SRD PT6262 8 Speed Build
Lee P
  • Replies 315
DAW pulley set supplied and polished by Rob, thank you mate :)
Everything was very dirty and covered in oil so we gave it a clean up and painted some parts.
New FMS seal, crank pulley and TRD thermostat fitted.
Me and baldy are in trouble if you keep getting good with the rattle cans! lol. Not having a SRD Polished lower water neck?
No doesn't need it on this one.
Lol... We even have an oven now to bake the parts in, they come out so much better.
Stunning and quick work as usual. Great attention to detail. :thumbs:
Might be worth changing the power steering cooler hose pictured as it looks in similar condition to one I've just had fail.
Will save a bit of hassle and potentially a lot of mess later on especially as you have just had it all cleaned up.
Keron on here will have a good one in stock. :)
Edited by st3ven1 (see edit history)
Nice work :thumbs:
Silly question maybe but what's the benefit of top feed over side feed injectors, if any?
Most aftermarket injectors are top feed so if your going for a big fuel system and changing the rail then the top feeds are needed and will flow more fuel.
