monsween Posted January 19, 2013 Share Posted January 19, 2013 Well I've got a leaking fuel pipe! It's the furthest away from the passenger side. I'm guessing it's the return line but can someone confirm? I'm intending on flaring it and fitting a flexi fuel pipe. I know that it really should be completely replaced but dont have the time to drop the tank to do it! Am I going to be flamed for this being dangerous? Quote Link to comment Share on other sites More sharing options...
Havard Posted January 19, 2013 Share Posted January 19, 2013 I had mine on the NA pieced and ran it for two years without any problems. They don't normally "go" in that area. They are mostly where the pipes sit above the rear suspension in a little plastic holder that retains water. Quote Link to comment Share on other sites More sharing options...
monsween Posted January 19, 2013 Author Share Posted January 19, 2013 There is a plastic cover there too and since the cars been sitting for 3 months it's probably rusted through from that TBH Quote Link to comment Share on other sites More sharing options...
safcdixon Posted January 19, 2013 Share Posted January 19, 2013 If its the return line i would just put a piece in, if its the pump line the i would try and replace it all, i had problems on my escort rst with the repaired pipe blowing off once i had fitted a bigger pump and there was more pressure running through it Quote Link to comment Share on other sites More sharing options...
bignum Posted January 19, 2013 Share Posted January 19, 2013 Check out your brake lines too. Quote Link to comment Share on other sites More sharing options...
monsween Posted January 27, 2013 Author Share Posted January 27, 2013 Brake lines are ok, bought some 5/16" fuel pipe and clamps to get me back on the road. Anyone know who does braided fuel lines with stock fittings on them? Quote Link to comment Share on other sites More sharing options...
monsween Posted February 3, 2013 Author Share Posted February 3, 2013 Back to the top. I've fixed the big leak but found a few more weeps that were covered up by the main bit so i'll just have to replace them all. Can I uprate these or OEM parts? Quote Link to comment Share on other sites More sharing options...
Ian C Posted February 4, 2013 Share Posted February 4, 2013 It's just a fuel line, oem it or bend your own to fit (cost vs utter ballache). Quote Link to comment Share on other sites More sharing options...
