How to adjust the speed from a 110 mph to 180 mph speedo
BOB B
I'm in the process of getting 180 MPH dial set, the one I have now is 110 dial set, the cars speed is de-restricted so the needle goes off the clock (or it would if I were to go that fast).
My question is: how (when fitted) do I adjust the new speedo to the correct speed? or would it be easier if I took it to a garage?
I didnt know there was a 110mph gauge, from memory a restricted motor will only do 112mph.
I think he means changing from JSpec clocks to UK Spec ones which have a higher top speed on them. He obviously want's them for track days :sly:
I seem to remember some UK importers got 110mph overlays from somewhere. You need a Speedo Converter/ Delimiter combination. Like this one:
http://www.ebay.co.uk/itm/121053126641?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
It corrects the pulse to the speedo so it works with 180 Mph clocks and sends a clamped 110mph signal to the ECU to delimit.
Lyndon.
Thanks for the discussions people, thanks Lyndon, I think mine is a bit of a weird one, my speed dial only shows up to 110 but when I have gone past that (on the track) the needle goes past that mark and comes up to the stops, so its not being limited to 110, it is also reading the correct speed as per the sat nav.
I will wait till I get the 180 one take the dash out and see what is there, I would have thought there was some way of adjusting the de-limiter to get the needle to read the correct speed on the new dial.
Once I have had a look and play I'll post again.
Thanks.
To clear up any confusion, JSPec cars came with the same speedo face (the clock in the dash) as the UK cars, but it was labelled "km/h" instead of "mph".
To convert the SPEEDO CLOCK (i.e. not the speed SIGNAL), the cheapest & crappiest way to do that is to put a NON-OEM mph overlay (a "110mph speedo") on top of the km/h speedo. Hence 110mph ends up being roughly where 180 kp/h was; these are roughly the same speeds. Obviously this is ok, but means if you ever delimit the car and want do do more than the factory limiter, your speedo needle will want to keep going past that point and at that point you won't have a clue what speed you're doing and you risk damaging the speedo as you clatter the needle into the other side of the 0mph stop the needle rests on when you're not moving.
The better way of "converting" the speedo, is to convert the speed SIGNAL, not the speedo face. By fitting a decent speed signal converter, this little box of tricks will put the original speed signal through a kph/mph multiplication, chucking a mph signal out the other side. You connect THAT signal to the speedo face, cruise control and power steering, and if you bought an all-in-one delimiter, you also put the "clamped" signal to pin2 IIRC of the main ECU. The only thing left to do is turn your "km/h" CLOCKS to read "m/h"; how? Cover up the "k". Job done.
Sorry to those who already knew all this, but there is always a lot of misunderstanding about what a conversion involves.
http://mkivsupra.net/vbb/showthread.php?112141-How-To-Install-a-Speedo-Convertor-and-Delimiter
This sounds like you have a speed delimiter at the ecu, but no converter at the speedo head (KPH to MPH). You can still use that converter I sent a link to, but you just don't connect the grey wire to the ecu.
Lyndon.
Thanks.
