Kaan W Posted January 16, 2013 Share Posted January 16, 2013 Ive been looking at electrical diagrams but as mentioned before I havent a clue when it comes to elctricals. I need to connect my stereo up properly as there is no wiring for it and thought there must be part of a loom that plugs into one or two of the connector blocks on the left side of the transmission tunnel. At the moment my stereo is wired completely wrong by a previous owner and has wires T'd into other parts of the loom all over the place and it just looks horrible. Also I need to connect my cigerette lighter up for a satnav asap as there is no wiring for this what so ever. Is there a cable for this that plugs in somewhere? Thanks. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 16, 2013 Author Share Posted January 16, 2013 Just bumping this as I need to plug a satnav in and need to know where to connect the wires to? I could bodge it and go straight to the battery but then it will have to be done again properly at some point. Quote Link to comment Share on other sites More sharing options...
Littler Posted January 16, 2013 Share Posted January 16, 2013 did it not have an iso block that the current head unit is plugged into? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 16, 2013 Author Share Posted January 16, 2013 did it not have an iso block that the current head unit is plugged into? No there was just a few little wires that I connected too for power and had to cut the block off and twist the wires toether for the speakers. I think someone said there should be a bit of loom that plugs into one of the white connectors at the back? Quote Link to comment Share on other sites More sharing options...
Littler Posted January 16, 2013 Share Posted January 16, 2013 Ahh, that makes it a little complicated for you, I had the iso adapter and used it to plug it into the normal loom plugs so no messing with the wires apart from for the amp and sub. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 16, 2013 Author Share Posted January 16, 2013 Ahh, that makes it a little complicated for you, I had the iso adapter and used it to plug it into the normal loom plugs so no messing with the wires apart from for the amp and sub. I know and also looks very messy. Do you know whats suppose to plug into the white connector block on the left of the trans tunnel? I think theres three and its the one at the back with nothing plugged in. Quote Link to comment Share on other sites More sharing options...
Littler Posted January 16, 2013 Share Posted January 16, 2013 I haven't got a clue without stripping my dash out but my car is with Chris Wilson so can't look lol, I'd hope for someone to come along with a pic or wiring diagram Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 16, 2013 Author Share Posted January 16, 2013 Ok thanks anyway Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 17, 2013 Author Share Posted January 17, 2013 Has anyone got a clear diagram of where the cigerette lighter should be wired to? Or if I wire straight in to the live circuit what amp fuse do I need? Quote Link to comment Share on other sites More sharing options...
