Crank bearings
Benjy
Went in to Toyota today to see about some bearings for the crank mains and big ends and apparently I have to measure the crank?
Has anybody else heard of this? And is it just better to get some uprated ones, or will the crank need measuring too? £180 a set + vat was sort of swaying me towards paying a little more for some uprated ones!
£159.04 inc VAT with free delivery. With any engine you build you should plastiguage to check the bearing clearance, thats what we do anyway.
Ok mate. Just picked up a nice set of lightened and balanced con rods, so will probably be in touch soon mate. Cheers!
  • 1 month later...
The crank / block grading is only applicable to new engines on the production line. Once the crank wears the micron differences in shell thickness become pretty irrelevant and unless you have a given grade and Plastigauge to play with you may find it simpler to buy after market shells that are not graded, and take away all that stress :)
