Tyre wear / rear wobble
masterfett
Hi guys quick question, i have an issue with my car that I'm hoping someone can shed some light on :) basically my car has a horrendous wobble from the back end, it is ok under acceleration but as soon as you lift off it shakes about terribly.. It has also managed to go through a set of tyres in 3 months (no not due to excessive right foot action) just a small commute to work and back each day... I'm wondering if anyone has any idea as to what could be causing this, doesn't seem to be any play in the wheels..
Thanks in advance :)
the rear suspension hasnt been touched, unless it was prior to ownership but looks standard to me. the bushes dont look bad to me however im not an expert, changing the pads next weekend so will check again next weekend.
and it was laser alligned after the tyre change .. so im assuming thats all a ok.
thanks for the response :)
I'd have the geo checked again, whoever did it might have done it wrong, seen that happen so many times.
Never assume is my motto ;)
I'd get it on a ramp asap if its as bad as you say, go round all the bushes and do
a bolt check at the same time making sure everything is done up to the
correct torque figures, half these places don't even have a torque wrench
let alone use them.
If all is okay i'd then get it re aligned, get a free check done somewhere other
than the first place you used.
Some laser alignment places are a joke, i've recently used 2 trying to
get my Landcruiser right !!
