markssupra Posted January 15, 2013 Share Posted January 15, 2013 Hi all, As title really, I ordered a 10MM DOUBLE HEX SOCKET, part no. SADM10E from Snap-On on 31st Dec but could be delayed another few weeks before I see it as its coming in from the US. Has anyone got one got one I could borrow so I can get my head off, engine strip down now seems to be taking forever. I do have a standard 10MM hex but dont fancy stripping the head bolts because of the wrong tool. Thanks Mark Quote Link to comment Share on other sites More sharing options...
Marco79 Posted January 15, 2013 Share Posted January 15, 2013 You can buy one from halfords for £8 mate Quote Link to comment Share on other sites More sharing options...
markssupra Posted January 15, 2013 Author Share Posted January 15, 2013 Thanks, I did ask in my local Halfords and motex, only ones they had were triple square, similar but not right. Quote Link to comment Share on other sites More sharing options...
Marco79 Posted January 15, 2013 Share Posted January 15, 2013 That's a shame my branch sold them and made my head bolts a breeze! Quote Link to comment Share on other sites More sharing options...
spikedjack Posted January 15, 2013 Share Posted January 15, 2013 Halfords should have a 16point socket in stock no issues :? Quote Link to comment Share on other sites More sharing options...
Marco79 Posted January 15, 2013 Share Posted January 15, 2013 Mine had it on the shelf but buy the 1/2" drive as I first tried a 3/8" drive and it sheared (they replaced it free of charge as per guarantee ) Quote Link to comment Share on other sites More sharing options...
st3ven1 Posted January 16, 2013 Share Posted January 16, 2013 Halfords should have a 16point socket in stock no issues :? As per the OP's first post he is after a HEX socket(six sides). That's about the only thing that lets the halfords sets down, is they don't have any hex sockets except the impact ones, every socket I have is a hex. Sorry OP, not helping. Quote Link to comment Share on other sites More sharing options...
Josh Posted January 16, 2013 Share Posted January 16, 2013 To take the head off the NA engine I have, as it didn't matter, I had to give the ratchet a damn good kick to get them to turn. I'd have thought to be careful, you'd need a long bar for some leverage. Not that this helps you, just saying Quote Link to comment Share on other sites More sharing options...
spikedjack Posted January 16, 2013 Share Posted January 16, 2013 As per the OP's first post he is after a HEX socket(six sides). That's about the only thing that lets the halfords sets down, is they don't have any hex sockets except the impact ones, every socket I have is a hex. Sorry OP, not helping. Apologies, I read double hex as in 6x2! Machine mart should have a Clarke pro 6 sided hex socket no issues. That's where my 6 sides are from Quote Link to comment Share on other sites More sharing options...
markssupra Posted January 16, 2013 Author Share Posted January 16, 2013 Thanks all, I do have a normal 6 sided '10mm hex' bit on a 1/2 drive. This does fit the stock head bolts but only engages at 6 points. Thats why I would prefer the 12 sided double hex or bi-hex bit. My son may have found one one Ebay, just checking with the seller. Quote Link to comment Share on other sites More sharing options...
martin p Posted January 16, 2013 Share Posted January 16, 2013 (edited) Edit - Nope just checked mines gone missing Edited January 16, 2013 by martin p (see edit history) Quote Link to comment Share on other sites More sharing options...
st3ven1 Posted January 16, 2013 Share Posted January 16, 2013 Apologies, I read double hex as in 6x2! Machine mart should have a Clarke pro 6 sided hex socket no issues. That's where my 6 sides are from Ah well apologies Mr spikedjack, it seems this is one of the very rare occasions where a 12 pointed socket is needed. However if you have a 6 sided socket that has the corners "cut out" in a semi-circle to allow the socket to sit on the flat of the bolt rather than the corner, then this will also be less likely to slip. Basically you are then applying the pressure to the "meat" of the bolt rather than the corners which are more likely to round. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 18, 2013 Share Posted January 18, 2013 A single hex tool *IS* the right type. They are effectively normal Allen headed bolts. Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 18, 2013 Share Posted January 18, 2013 To take the head off the NA engine I have, as it didn't matter, I had to give the ratchet a damn good kick to get them to turn. I'd have thought to be careful, you'd need a long bar for some leverage. Not that this helps you, just saying You shouldn't do that to ratchets, you should use a breaker bar Quote Link to comment Share on other sites More sharing options...
