Kaan W Posted January 15, 2013 Author Share Posted January 15, 2013 Used a Renault 5 rubber exhaust bobbin to locate, isolate and connect the O.E. cable to extension. Cable size 0 for simple fit, or down to size 2 with additional cable for ignition circuit. 100 amp mega-fuse. Im mounting my fusebox next to the battery so I guess I need to run a fuse in a single piece of 0 gauge cable from the battery going to the starter then T off some 2 gauge for the fuse box? fusebox. Link to comment Share on other sites More sharing options...
David P Posted January 15, 2013 Share Posted January 15, 2013 That'd work, crimp and solder all joints. Link to comment Share on other sites More sharing options...
