"racewiring' a 2jz
s50b30
Hello there.
I bought a 93 supra tt 6 speed a while ago.
It will be a trackcar only.
Problem is it had only the engine harness+ upper and lower fusebox plugs, and orange, grey and white plug.
The rest is missing.
I already set up a switch panel, just wiring to be done.
I have found the wires for:
Starter, 3 pins on ecu that need 12v, 12v for coilpacks and injectors?
Fuelpump run straight of a relay.
Is there anything else?
Speed sensor on the gearbox is also missing.
Is it necessary to have that? Will it affect the ecu?
Hoping someone can answer.
Thanks in advance!
