engine managment help
craig l
Today my engine managment light came on the car was losing power and spluttering, i managed to get it home barely touching the accelerator. I tryed to check the error codes im sure it was blink slight pause blink 4 blinks pause 4 blinks then blink slight pause blink hope this makes sense to someone because im not very mechanically minded so im stumped. Its a jspec bpu man tt thanks in advance.
I've been thinking about this - it's difficult to tell if you're reading the codes out right (with the right time space between codes and digits) but you could be getting a code 2 (MAP sensor) and a code 3 (Ignition signal).
It may be a MAP sensor fault or a split or detached hose. Have you checked your ignition though yet?
