HKS Exhaust Q
Jellybean
HKS USA - which is no longer trading - used the name Hiper for their exhausts. HKS Japan use the name Silent Hi-Power.
HKS USA exhausts had different part numbers to HKS Japan and the exhaust designs were different.
31019-AT005 is the correct part number for the HKS (Japan) Silent Hi-Power for the Supra.
thanks Nic, found that when I googled it; they both looked the same but called hiper muffler in the US!
Surprised it is a hell of a lot cheaper to get it here versus the UK! Murraymotorsport again !
One more q, the decat pipes the supra are mainly 2.5 inch ; should you be running 3 inch pipes?
I think the his comes with a 2.5 to 3 inch adapter?
With the j-spec stock turbos it doesn't really make any difference as you need to fit a restrictor ring either way. The flange on the exhaust is the same whichever size you go with.
I cant find any information on the HKS decat pipe (AKA Mid-pipe) (Other than the Part Number-- HKS-3103-RT006) is this 3" or 2.5"?
Better getting the Blitz midpipe over this one because it is larger and 100% stainless steel?
All these Mid-pipes should mate up to the HKS Slient hi power system?
Edited by Jellybean (see edit history)
