RB-GTE Posted January 10, 2013 Share Posted January 10, 2013 I am in the process of trying to locate a dampening adjustment key/pin thingy for my Ohlins. They came setup like this from Japan. Most likely on the hardest option. I need to soften up my suspesnion for the street a bit. After I get that sorted, I'll be upgrading the front/rear sway bars. Strut bars and wheel setup I am already set. What are the kind of alighnment's you guys are running? I'm looking for something that will help me 'feel' the front wheels more, more aggressive and sharper handling, but also something that'll give me decent tyre tread wear. From what I recall these are my current settings, from a shop that was supposed to do the 'Lance' alighnment but didn't get it right after I saw the print out. -0.8 front. + 5.0 caster, 0.00mm toe - 1.2 rear. 1.00 toe Cheers Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 10, 2013 Share Posted January 10, 2013 To be honest I would take it for a professional geometry setup and tell them exactly what you want to use the car for which in your case just a fast street setup. Alot of people take there cars to wheels in motion (WIM) which is where im taking mine to be done. Theres no point guessing whats a good setup it needs to be done with expensive computers and machinery. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted January 10, 2013 Share Posted January 10, 2013 To be honest I would take it for a professional geometry setup and tell them exactly what you want to use the car for which in your case just a fast street setup. Alot of people take there cars to wheels in motion (WIM) which is where im taking mine to be done. Theres no point guessing whats a good setup it needs to be done with expensive computers and machinery. Hope this helps. WIM are excellent Quote Link to comment Share on other sites More sharing options...
Iky Posted January 10, 2013 Share Posted January 10, 2013 To be honest I would take it for a professional geometry setup and tell them exactly what you want to use the car for which in your case just a fast street setup. Alot of people take there cars to wheels in motion (WIM) which is where im taking mine to be done. Theres no point guessing whats a good setup it needs to be done with expensive computers and machinery. Hope this helps. And knowledge, dont forget the knowledge! Known good place are Chris Wilson and WIM. They have set up hundreds of Supra's before so should be able to dial in the settings for the characteristics your after. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted January 10, 2013 Share Posted January 10, 2013 Also, depends how good condition your suspension is in, no point in any of it if you have flappy ball joins, knackered bushes and dodgy dampers. Quote Link to comment Share on other sites More sharing options...
Thorin Posted January 10, 2013 Share Posted January 10, 2013 The Lance alignment settings are a good bet http://mkiv.com/techarticles/lance_alignment/index.html Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 10, 2013 Share Posted January 10, 2013 Overall feel is hampered by the overly helpful power steering system. You could swap it out for an electric system, and fit a sensitivity switch, but this would be a PITA on a Supra (I'd imagine) Quote Link to comment Share on other sites More sharing options...
Iky Posted January 10, 2013 Share Posted January 10, 2013 Overall feel is hampered by the overly helpful power steering system. You could swap it out for an electric system, and fit a sensitivity switch, but this would be a PITA on a Supra (I'd imagine) Regarding this, I've read something on one of the usa forums that someone had wired something into the pps solenoid to control it. That maybe an easier option for someone looking to do this. Possibly... Quote Link to comment Share on other sites More sharing options...
spikedjack Posted January 10, 2013 Share Posted January 10, 2013 Front: Camber:-1.0 degrees Caster:+5.0 degrees Toe: 0.0mm Rear: Camber: -1.5degrees Toe in (total) 1.0mm Quote Link to comment Share on other sites More sharing options...
RB-GTE Posted January 10, 2013 Author Share Posted January 10, 2013 Front: Camber:-1.0 degrees Caster:+5.0 degrees Toe: 0.0mm Rear: Camber: -1.5degrees Toe in (total) 1.0mm I'll have to go to a proper shop that can actually do the Lance alighnment Quote Link to comment Share on other sites More sharing options...
spikedjack Posted January 10, 2013 Share Posted January 10, 2013 As much caster as possible, more if you can get it Quote Link to comment Share on other sites More sharing options...
