Active Spoiler ECU pinouts? Full wiring diagram
inazone
Hi,
Does anyone have any info on the Active Spoiler ECU pinouts? I am currently installing my active spoiler and it turns out i have the plug at the bumper end however no loom in the dash. I have seen various diagrams to create a manual switch however i would prefer to wire it up as it is intended.
I have searched the forum quite extensively but i can not seem to find what i need. The ECU plug has 18 pins, the Spoiler plug has 5 pins, the switch has 7 pins so if my logic is correct i would guess i need to connect the ECU to 4 other differnent points on the car?
Any help would be greatly appreciated.
Alex.
Hi, i have seen this info, but i am struggling to work out exactly what connections i need to make, unfortunately i am not an electronics engineer although comfortable with wiring and using a soldering iron. What i need is for example ecu pin 7 goes to speed sensor wire..... ect. I can then make up a loom and may be try and have a go at making it manual/auto.
It's all there,
http://homepage.ntlworld.com/peter.betts/supra/TechTips/spoiler5.gif
http://homepage.ntlworld.com/peter.betts/supra/TechTips/spoiler4.gif
There are little numbers around the grey shaded area, I'm pretty sure these are pin numbers.
Looks like to me, pins 12 and 13 aren't used.
Pin on spoiler ECU
1- ODO and TRip and then to Speed sensor pin 3
2- Pin 8 on spoiler switch
3- Pin 4 on spoiler switch
4- Don’t know wtf that is some sort of lamp and then to speed sensor pin 1
5- Pin 1 on spoiler motor ( –VE on motor)
6- Pin 2 on spoiler motor (+VE on motor)
7- Think it’s fuse for spoiler
8- Think it’s connected to pin 7
9- To the alternator for some reason
10- To pin 5 on spoiler switch
11- To another fuse connected with the ecu
12- Not shown
13- Not shown
14- Pin 4 on spoiler motor
15- Pin 3 on spoiler motor
16- Pin 5 on spoiler motor
17- Think it’s earth
18- Think it’s earth connected to above.
That's what I can make out of it. I might have made mistakes.
Edited by Iky (see edit history)
Hi Iky,
Thanks for your responses, i printed out those diagrams and stuck them together which helped alot in working out the pin IDs. Its good to see that you have come to the same conclusions as me. I think pin 4 goes to the dash as a warning lamp. Not certain what the alternator feed does but it may tell the ecu that the engine is running. All i need to do now is make a loom and find a spare ecu plug and switch plug?
